Question about Sony Playstation 3 (PS3) Console
Turns on then about 1 second later the on/off indicator light blinks an amber type color and shuts off. the on/off indicator blinks red.
    Novelist:
  • 142 Answers
The blinking light is typically the result of a heating issue but can also be caused by both a malfunctioning hard drive or a lose connection. The big problem with this is the $150 price tag that Sony charges to fix the issue. Below is a link with a more detailed description of the problem.
http://www.articlesbase.com/electronics-articles/dealing-with-a-ps3-blinking-red-light-1678489.html
I hope the info listed above has helped in some way.
If possible please rate this solution.
Posted on Aug 27, 2010
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Replaced lamp a month ago. tv turns on then shuts off with blinking amber color. i do not have the original remote. What does it mean when blinking amber light comes
don't know what model but with lamps being replace, a few things are important, 1 the right part for your set, 2 not touching with hand, 3 cleaning the area first good, free of dust.
Jan 12, 2011 | Televison & Video
The maintenance requierd turns red what do I do?
This is just a reminder, which changes color when a set amount of mileage is put on the car since the last time it was reset (7.5k miles). To reset, just insert the key into the slot in the dash. It will reset to 'green' color. On '92 Accords, the slot is below the tachometer, near the indicator, 93's should be similar. If you have any other questions about this, or you need me to clarify something, please just ask.
Apr 05, 2010 | 1993 Honda Accord
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
