Question about HP 1050 Plain Paper Inkjet Fax
One cartrage print how many papers - HP 1050 Plain Paper Inkjet Fax
    Guru:
  • 731 Answers
HP 20 Black cartridge for this printer yields 500 Pages.
Posted on Aug 27, 2010
HP designjet110. Put in new cartrages and not print
Whether you removed the seal on bottom of the head and contacts. If the printer recognized your cartridges, it means you removed the seal. Not print means the printer is showing error or blank white paper out
Jun 03, 2017 | HP Office Equipment & Supplies
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
1500 series all in one.check cartrage or paper light is blinking
Hi There
Try cleaning the Contacts on the cartridge not making proper contact with the print carriage.
All the best Pineworks
Apr 01, 2010 | HP PSC 1510 All-In-One InkJet Printer
Not printing. Will not take in the printing paper. Information window tells me to aline the ink cartrage. I have replaced new ink cartrages. Somthing is trying to turn as it is making a ratchet noise. ...
yes you have to print out a alinement sheet then put it in the scanner and scan then follow the directions to aline the print cartrigde once it is alined you ready to go. and you have to do this each time you replace the cartridges.
Oct 07, 2009 | HP PSC 2175 All-In-One InkJet Printer
Blank printin on the right middle ohe paper
Toner may be low. Check the Toner level. You may have to clean the printer too if you have a new toner cartrage installed. You might also have a bad printer where its not able to fuse the toner in that area any more.
Apr 22, 2009 | HP Office Equipment & Supplies
Ink will not dry on photos. comes out real wet.
in the printer little sceen go to the settings and and select Clean Print Head
Dec 27, 2008 | HP Photosmart C5280 Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
Printer not printing says to see user guide unable 34
i had this problem, paper was jammed in between printer cartrage and the right wall ( when lookin at it from front).
open top flap of the printer, u will have access to the cartrage (the thing that moves side to side whilst printing) move that to the left and have a look on the right hand wall. you should see quite a bit of paper jammed up in that area, make sure u clean throughly, get a torch if psooible, close flap then ure eon ure way
Sep 12, 2008 | Office Equipment & Supplies
Dell A920 Paper will not go into the printer without a jam.
check cartrages plz your cartrages ok after you clean pickup roller i hope your pro. solve
Dec 20, 2007 | Dell A920 InkJet Printer
HP 1050 Plain Paper Inkjet Fax Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
