Question about Sony Televison & Video
KDF-E50A10 Sony LCD-Bright vivid and atypical coloration of the complete screen with figures blurred and fuzzy. What is my problem?
  • 1 more comment
  • PB Noack Aug 30, 2010
    I HAVE A SONY KDF-E50A10 THAT HAS A BLURRED AND FUZZY PICTURE WITH BRIGHT COLORS THAT OCCURS INTERMITTANTLY FROM CLEAR PICTURE TO FUZZY. WHAT IS THE PROBLEM WITH THE TV? IT IS A 3LCD REAR PROJECTION TV.
  • PB Noack Aug 31, 2010
    How does one re-align the lenses? I there a written procedure for doing this? If so, where may I obtain a copy of it? What degree of technical difficulty is it to re-align the LCD's?
    Is it possible the color block is dirty?
  • Sony Master
  • 11,800 Answers
The optical engine  - the set of lenses and prisms that merge the image from the 3 lcd's and project it on the screen no longer works correctly - the lenses are out of focus.
The only thing you can do is to take the engine out and try to realign the lenses. If the lenses are deformed or you can't push them back into place then the engine is dead, and the tv with it - it will cost you more than $800 to replace them.
Posted on Aug 30, 2010
  • 1 more comment
  • Azrael SRL Aug 31, 2010
    The lenses are from plastic and are just pressed in place in the casing of the optical engine - from the heat of the bulb they expand and in rate cases just pop out of the recess in which they should be located. Usually when they expand from the heat the recesses hold them in place so they deform - when they cool they remain deformed and the image gets fuzzy. To fix them if they aren't deformed is to press them back in their correct position.
    No, the LCD can't be dirty - if they would be like that then the image would be dull, darkened and with spots, the opposite of what it is now.
    How difficult is it to get at the plastic lenses? Where are they located? Is there a written procedure to show me how to perform the correction if it indeed can be performed?
  • Azrael SRL Sep 01, 2010
    To access the optical engine is quite easy, all you need is a screwdriver to remove the screws that attach it to the LCD block and the base of the tv.
    No, no written procedure. Actually the optical engine is supposed to be an unserviceable unit - if it fails for whatever reason it should be completely replaced - so no procedure at all is available. You must act just using your common sense, after looking at the damage.
  • Sony Master
  • 19,396 Answers
Hi.
Problem is likely a defective a defective LCD display. A faulty light engine and a defective video controller board may cause similar problems.
If problem is the light engine or the LCD panel, then the TV is usually considered beyond repair.
This is a repair that will in any case result expensive, requiring long hours testing and parts that are not cheap. The only way you can have this repaired at an affordable cost is by calling Sony and having the TV repaired at manufacturer low price.
Sony eSupport - Electronics
Posted on Aug 27, 2010
Hey I need to know the sony part number for a "Sony Wega KDF-E50A10 power supply block" in order to buy it and replace it. It seems sony doesn't easely gives you that number so you have to send...
Power supply board part number for Sony KDF-E50A10 is as follows:
A1113732A .... GT BOARD COMPLETE
and if you are asking for ballast power supply board part number, it is as under:
146893611 ... POWER SUPPLY BLOCK
Hope these info will help you.
Thanks.
Jan 12, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
My TV screen went black and now the bottom light that is usually green, now blinks red 5 times in a row. Can you please tell me what is wrong w/ it?
5 times red standby light blinking shows problem with ballast supply board in Sony KDF-E50A10 model tv, ballast supply board provides high voltage to lamp to produce high bright light.
Please check/ replace ballast supply board in tv by local tv repairman.
Thanks.
Nov 07, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
My Sony KDF-E50A10 has a color problem and it happened all at once, not gradually. I don't have any red. Now my blues and yellows are very vivid. Is it a part I can replace? If so, can you let me know what...
Hey I'm really sorry to hear that it looks like your LCD chip is burning out and the problem will only get worst if you don't replace the OPTICAL BLOCK this problem will cost you around $350.00dls to fix check this link out a lot of people have the same problem check it out
http://www0.epinions.com/msg/show_~threads/cat_id_~13/id_~9877/forum_id_~127
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!
Oct 04, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
I have a Sony WEGA backlit LCD 42 with a blue spot.
sony canada is replacing the color block on all of the 2006 2007 model year of the Grand wega
Oct 16, 2009 | Sony (XL-2400) Projector Lamp for...
"my kdf e50a10 has a green screen Is this is a lamp problem or an
Green picture is caused by the light engine (the projection part of tv) failing and has to be replaced. Sony has extended the warranty on some models so you might be in lick. Contact them with model and serial number they can help setup repair if you qualify. If it is not covered it can cost between $1000-2000 to fix, which is way too much.
Rustym62
http://www.the-tv-dude.typepad.com
Mar 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
No red color
Scott,
what do you have hooked to the set?
How is it hooked to the set?
does this happen on all inputs?
Jun 24, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
KDF-E50A10 Sony TV Purchased May 06
IF THIS HAPPENS ONLY WHEN USING HD SORCE THEIR IS A MODIFICATION TO BE CARRIED OUT.IF NOT THE OPTICAL BLOCK WILL REQUIRE REPLACING.
Nov 10, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Verticle lines following the color spectrum across the screen.
Had Sony KDF-E50A10 that had the same line problems after 16 months. Was fine at lunch time and when got home from work and turned it on, they were the lines. Want over $800 to fix it. Told me it was the B-Board assembly. Sony was no help. They have exteneded the warrenty on another part that works along with the B-Board but not just the B-Board itself, so probably not any more Sonys. I'm going with LCD now.
Oct 03, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
