Question about Freezers
Frigidaire side by side model# PLHS269ZCBO
Makes ice only once or twice a month.this is after putting 275.00 into a new maker and two service calls.water flow is good and freezer is cold.thanks
  • 828 Answers
How cold is the freezer? Check the condenser coils for cleanliness and clean if necessary. Condenser may be located in the back behind a fiber panel. Ice maker is dependent on temperature and if the freezer is not reaching a low enough temperature it will affect your ice production.
Posted on May 16, 2008
Why is icemaker not working
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, model# FPHG2399PF. Please follow these steps to resolution:
    1)Make sure the ice maker power switch is on. This button is located on the ice maker itself.
    2)Make sure there is not a small cube caught in the ice maker itself. If there is, carefully remove it.
    3)Check your water filter. Water filters should be changed roughly every 6-8 months. Also make sure your water filter is seated correctly. Try taking out the filter and re-installing it. Listen for 2 clicks and make sure it is flush with the water filter housing.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FPHG2399PF Professional 23 Cu....
I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
Oct 28, 2010 | Thermador Freezer FREEDOM® T24ID80PLS
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
My Frigidaire side by side is not making ice. (Model GLRS267ZAW1)It goes through the cycle but no water is getting into the icemaker. I can pour water in to the icemaker and it makes the ice and dumps it....
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Oct 03, 2009 | Freezers
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
May 01, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
Ice maker is broke how do i replace need to replace whole ice maker
If its broken is probably better and cheaper to get a new one than try to fix it or pay to somebody to do it.First unppluged the fridge take the two scrwes that holds the ice maker to the freezer side wall and another one in the bottom of the ice maker once is loose you'll see a plastic plug ,pull itout and you can take the machine off and put a new one.When installing the new one make sure that the filling plastic tube is right through the hole in the back of the ice maker.
Apr 23, 2009 | Kenmore Freezers
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Freezers Logo
199 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
