Question about Toshiba Satellite Pro A200-EZ2204X Notebook
Cd rom donot work - Toshiba Satellite Pro A200-EZ2204X Notebook
  • 2,567 Answers
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive.
Posted on Aug 27, 2010
How can I get my epson sx115 scanner/printer to work and pair it with my laptop with the cd rom instructions ? I put the printer wire in recently and does not print.
Use the setup wizard given in the CD along with the printer.
Check if the printer drivers have been installed in the laptop.
Donot connect the printer before installing the software.
Initially use the CD and follow the instructions on the screen
You will be prompted to connect the Printer after the installation is done.
Connect and then try a test print when instructed.
Jun 02, 2011 | Office Equipment & Supplies
I download hp 5590 drivers from hp.com i tried to install it, the proces eend normaly, but if i connect the scanner, windows xp show the new hp connect like its not installed yet. I check at add remove...
FIRST UNINSTALL YOUR PRINTER COMPLETELY
REMOVE ALL CABLES OF PRINTER (USB)
REBOOT YOUR SYSTEM
HAVE DRIVER CD
PUT IT IN ROM(CD/DVD)
INSTALL PRINTER SOFTWARE
DONOT PLUG THE USB CABLE UNLESS & UNTILL PROMPTED
PLUG USB WHEN ASKED
FINISH INSTALLING PRINTER
NOW YOU CAN FIND THE SCANNER
Feb 15, 2011 | HP Scanjet 5590 Flatbed Scanner
Format is impossible in acer Aspire aoa 150 lus050ao
need to get bios setting for adjust External drive as first drive.
Jun 14, 2009 | Acer Aspire 5315 Notebook
Dvd keeps kicking out of the CD ROM when tring to copy.
Hi ,
The dell desktop demension 2350 that you are using does not have a dvd burner. Hence when ever you are putting the dvd burner it throws it out. Please instert a cd and you would see that it does not behave the same.
Hope this resolves your question .
Please donot forget to rate .
Mar 25, 2009 | Roxio Easy CD & DVD Burning
My cmputer donot play dvd
Windows XP does not play DVD's by itself you need
1) a DVD ROM (or RW) drive, and
2) DVD playing software.
Usually the Drive, or your PC will come with something like PowerDVD or some program like that.
Windows Vista and newer will play DVD's natively.
Jan 25, 2009 | Real Network RealPlayer Enterprise Manager
Fedora
When you start your computer Press F2 or F12 to make changes in Boot sequences.Make the CD-ROM or DVD-ROM 1st in the Sequence. Save the Changes and Exit.Before rebooting put the XP CD inside the CD-ROM Drive and reboot.
If you donot have Driver's CD of Motherboard,it is better to make Driver's CD before reinstallation.
Sep 19, 2008 | fedora Linux Operating System
How do i install canon multipass mp390 printer without the cd-rom
hi,Dear
you can, but you should have a dump in your sys or you can use usb pen drive to install this. if you have internet you can download it from canon site: http://www.canon.ca/english/index-customersupport.asp?pid=269 save it to your sys and install it.
Jul 27, 2008 | Office Equipment & Supplies
Hi problem audio
If you have a cd utility then insert it to your CD ROM and then install all the drivers..don't forget to install the audio driver that make your sound work.
If don't cd utility then you can search driver here:
http://www.compexinternational.com/downloads.htm
If this not work then, maybe board audio soccket fault.
may this help,
melnavz
PS:
pls donot rate me the solution do not solve the issue, but if is good then rate me fixya. thanks.
Jun 19, 2008 | Biostar P4M800-M7A Motherboard
Cd rom
its very simple .remove the outer cpu case.then remove the cd rom open itplace THE TRAY in RIGHT MANNER ONCE AGAIN . donot try to move the tray of your cd rom without opening the cd rom ,it might result in a permanent damage
Nov 03, 2007 | Packard Bell GCD-R580B (gcdr580b) Internal...
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
