When i try to save, extract or print document error (14) comes up... please help?
  • networkey May 11, 2010
    I have read from other forums that it has something to do with the PDF file or the Acrobat Reader. So better if you can give some more details to the problem you are encountering.
    What application/program are you using when you get this error?
    Guru:
  • 458 Answers
To extract and print PDF files from your PC, you need a PDF reader, like Adobe reader. Yuo can download one from online. Try version 8.0
Posted on May 14, 2008
I have HP 4600dn and getting service error 49.2FCC. What does that mean
I'm not certain of this, but its possible that there are embedded postscript fonts in your document that are causing the printer to choke.
What I would do is to load up your file in Publsiher, and then save it as a Word.doc file. and then try to print.
I just looked at the service manual and this is the recommendation to try first.
Apr 20, 2016 | HP LaserJet Office Equipment & Supplies
Epson sx440
There are several issues that can cause these anomalies where its not printing the full document. First, some people download PostScript drivers when their machine only handles PCL drivers. Secondly, sometimes the document itself has corrupt data and as it transfers that document to the machine, there is problems.
I suggest you open a PDF document and attempt to print it. If that document, and other documents print fine, then you know your error lies in corruption inside that particular document.
If you suspect that document is corrupt, there is several things you can do to potentially fix it. First, save the document in PDF form. This causes it to layer to one single layer and can more than likely solve the problem "temporarily" if you need the document quickly.
The second fix comes when you save the document in a different format. For instance, let's say you have Microsoft Office 2013. And this is a "word" document. Save it in XPS format, then close down Word. Re-start Word and then open that document that is saved in XPS. Now, click File Save As, and then re-save this as a Standard Word Document. Sometimes, this corrects the corrupted document.
The last alternative is, HOPEFULLY you have saved this document previously as other names. Re-open the older document, and TEST IT FIRST to make sure it is printing OK. Then, make your additional edits WITHOUT PASTING EDITS FROM CORRUPTED DOCUMENT. Re-save the document making sure to create a completely new name and NOT just save over existing document. Then attempt to print it out. This should solve the problem if it is a corrupted document.
If its becuase you have a PostScript Driver, then uninstall that driver, do to Epson's website and download the CORRECT PCL driver that corresponds with your operating system, ie Windows 7 Professional 64 bit... I hope this helps...
Aug 24, 2014 | Epson Stylus Multifunction Inkjet Printer/...
Oki B6250 Service Error 14....help please
I have an Oki B6250 ang keep getting a Service Error 14. When i clear all the documents pending it works but happens next time someone wants to print Its linked to 20 PCs
Nov 20, 2012 | Xerox Phaser 6100/BD Laser Printer
I am getting this error when trying to install anything on my win 7 ultimate. is there anything i can do to fix this? Says exactly this: "1152: Error...
1- Uninstall all the programes in control panel which you think you don't require
2- delete all leftover folders in program files outspark etc.
3- click start > run > type %temp% and delete ALL the files in that folder
( There will be like 3-4 u can't delete, dont worry about it ) also make sure you uninstall and delete the launchers.
4- Re download the PROGRAME ( INSTEAD of Saving it to DESKTOP, Save it somewhere else Like My Documents, Run it, And there you go problem solved.
At least that is how it worked for me, every time i was having that error i was saving it to desktop, after i did all the steps before and changed the location to my documents, it installed without any problems.
Aug 11, 2011 | Computers & Internet
Hi please help? My HP all in one deskjet f380 only prints certain documents, It starts as if its going to print, moving back and forth and then just stops and nothing is printed. The print job dissapears...
Try if one of these solutions help you.
1. Shut down you printer, wait a few seconds, start it again and try to see if you document is printing.
2. Install the printer again on your computer. This time, if possible use an other USB port.
3. If you can print PDF, you can try http://www.freepdfconvert.com/ and print your document after you mad a PDF.
Jul 07, 2011 | Office Equipment & Supplies
I am using DVDFab 5 to copy dvd, but I can not burn it. please log below. 14:14:08: Analyzing of DVD started 14:14:08: Analyzing of DVD completed successfully 14:14:08: Copy process started 14:28:57:...
looks like its making the image fine
try to use a different program like imgburn to make and image of what yoiu wanna burn then use that image to write to a new disc
http://www.imgburn.com/
May 06, 2011 | Computers & Internet
Page two of a word document prints so every other line is faint
do 1 thing, save document-2 as a pdf file and try to print one document @ a time. it will resolve the issue.
Jul 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error Message says "Cannot Print Booklet or Magazine due to Mixed Color Modes"
Might be a bug in the software.
Suggest try re-download again.
Dec 02, 2017 | Office Equipment & Supplies
Lexmark E232 printer problems in 8.5 x 14 page
Software issue for the printer. Uninstall driver and reinstall. If this does not solve it, it may be time for a new printer. Lexmark printers do not have a long service life.
Jun 23, 2007 | Lexmark E232 Laser Printer
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
