Question about Teac PD-D2410 5-Disc CD Changer
My cd player stops playing part way through a track it could be on the first cd or up to the third cd.Any help with this problem would be appreciated. Mal
  • 17,129 Answers
Possible fault in hte mechanism or the drive . Remove panel and allow the set to operate with good cooling on the main board. If there is no issue then close and check. If the fault occurs, confirm if the issue is relative to heat build up, check for visible fault in sections, touch for heating components. If you have a freezing spray use it to confirm. Clean up the optical , the drives and sensors for detection of the 5 cd trays.
If fault is consistent check the observation prior to the stop. does it stop on reading .. if so the mainboard may be running off in heat.
If the fault occurs inloading then it might be insufficient loading with possible errrors to the mP.
check this out carefully and with patience.
Posted on Aug 27, 2010
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Cd player starts, but stops play by 2nd track
Sounds like tracking motor and/or gear problem!
Check for a small crack on the tracking gear.
Parts not avalible from Bose though, they'll only
fix as a "flat rate"!
Apr 12, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
My Sony CDP-XA7ES CD Player can play only up to 6 to 9 tracks depending on the length of the tracks n then stops.
replace the spindle motor. the motor's speed varies while playing cds and a worn motor will not keep to the correct speed for playback of certain tracks on various points of the disc and will cause skipping and even stop altogether.
hope this helps.
Apr 02, 2010 | Sony CDP-XA7ES CD Player
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
Cannot turn off the machine
Try cleaning the laser with a cleaning cd.
May 20, 2009 | Sony D-NE20 Personal CD Player
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out. good luck
Apr 05, 2007 | JVC XL-FZ258BK 5-Disc CD Changer
Teac PD-D2410 5-Disc CD Changer Logo
673 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
