Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
The brushes do not rotate
How do I get the brushes to rotate. The switch is on.
  • millermeek Sep 07, 2008
    I have the same Prob. I have taken out the brushes but can't see anything wrong. I was looking for a manual that would tellme HOW to take it apart.
    Can you offer suggestions on how it comes apart so I can determine if the turbine needs replacing. If it does, I need instructions on that and where to get a part replacement. Any ideas? This is a great product until now.
  • Anonymous Mar 16, 2014
    rotating brush does not rotate
  • 1,673 Answers
The brushs are driven by a turbine, if not turning, it may be bad. You can take it apart and try to clean it out, or just replace it. Also pull out the brush block and see if the shaft that goes up into the turbine is broken off, itis broke, then replace the brush block.
Posted on May 15, 2008
Brush bar stops rotating when I recline the upright part beyond 45 degrees. Brush bar rotates but if I move the machine too far away, increasing the angle it stops. All cleaned out etc
There is a switch in the ball which is activated as you pull the handle back from the upright position. The lever that activates the switch pivots as the handle rotates backwards. Try to determine if this lever could be broken or mislocated somehow..
May 02, 2016 | Dyson DC40 Multi floor Upright Vacuum...
Why doesn't brush roller rotate?
Pat, if clean and belt OK, motor has burnt out, can be replaced.
Dyson DC24 How To Replace The Brush Bar Motor
Feb 25, 2016 | Vacuums
My Shark rotator is very hard to push at times, easy at other times. What makes it hard to push and how do I fix it?
Does it have a "brushes" lowering/higher switch?
Normally due to brushes being too low in particular on deep pile carpets??
check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
Feb 12, 2015 | Shark Rotator Professional Lift-Away...
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
Electrolux Z61a brush not rotating
There should be a rubber belt somewhere along that roller, probably in the middle, behind the bottom cover plate, Remove the plate. That belt may have just slipped off the motor shaft, but it may be broken.
The belt could possibly be installed in either of two ways. The motor shaft is not parallel to the beater bar (brushes), so the belt must twist to wrap around both the motor shaft and the beater bar. If it's twisted one direction, the beater bar will rotate the correct direction (as if drying to pull the vacuum forward). Twisted the wrong way, it'll rotate the opposite direction. Try it one way, then bump the power switch to verify that the brush is rotating the correct direction before putting the bottom cover plate back on.
Aug 10, 2014 | Electrolux Vacuums
Cleaning brushes wont rotate
I understand how important the brushes are when cleaning.
You may want to the check the pump belt for breakage for the brush belt and pump belt work in conjunction with the pump.
If you're still experiencing difficulty, you may want to have your machine inspected at one of our Authorized Service Centers. Here's a quick link to help you locate one in your area:
Mar 17, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
DC07 bottom brush does not rotate.
I can not pinpoint what exactly solved the issue. I opened the bottom conver, cleaned any presence of hair, cleaned all hoses (yes hose was completely clogged), made sure that the brush bar was engaged by switching the selector back and forth few times from Carpet to Bare floor. (On bare floor setting, brush bar won't rotate).
Now I am happy that the vacuum is completely cleaned and back in operation!
Nov 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover carpet cleaner f7425-900
the brushes are run on a vacuum the switch may no be opening
Nov 21, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
234 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
