Question about HP 1502 LCD Monitor
My hp1502 does not come alive. no light when power is connected.have changed the cable. should open the back?
    Scholar:
  • 137 Answers
There are lethal voltages inside your monitor even when its turned off and unplugged. If you are going to open it be very careful.
You may find some visibly swollen electrolytic capacitors, or some bad solder joints... but you will not be able to diagnose any other faults without some test equipment.
Posted on Aug 27, 2010
System DHC-FL5D shows a red light near power on switch but won't start
inside, some flap cable may have been disconnected. get it serviced. also let me know if you want to sell.
Apr 25, 2015 | Sony Audio Players & Recorders
How I change the battery
What is year--make--model? You can't get the battery in or out? Also, with some vehicles, you may be ahead to use a memory saver that plugs into cigar lighter or power outlet, to help keep some memory systems alive if you have to disconnect battery.
Some systems if they lose memory it can cause problems.
Mar 04, 2015 | Cars & Trucks
Sony DHC FLX5D hifi system shows a red light near power on switch but won't start
You opened the case to check the fuses, do that again and look at the devices that resemble small cans. See if the are bulging, leaking or exploded.
Jan 06, 2014 | Sony Audio Players & Recorders
Error codes for reader p1633 2005 F250
P1633 definition is Keep alive power,This can be generated when you have a interruption to the ECM memory,this can be caused by a bad battery connection,or a open fuse to the KAPWR (keep alive power)
Nov 11, 2012 | Cars & Trucks
Hp1502 stays black
If you see that the monitor is on by a power on light Then the graphic card could be bad or most likely the monitor is gone to haven. Borrow a friend monitor and attach it to your computer and see the result. also check your connections monitor to computer.
Mar 24, 2012 | HP 1502 LCD Monitor
Ford escape 2001 ,engine light on all time and code p1633 came when i did the scan ,how can i fix the problem
P1633 - Keep Alive Power Voltage Too Low Indicates that the Keep Alive Power (KAPWR) circuit has experienced a power interrupt.
  • Open KAPWR circuit
  • Damaged PCM
  • Intermittent KAPWR Circuit
QB1 CHECK BATTERY TERMINALS
    Note: If KAPWR is interrupted to the PCM (that is, when a breakout box is installed or the battery is disconnected), DTC P0603/P1605 can be generated on the first power-up.
  • Inspect the battery cables for loose connections, corrosion.
Are the battery terminal connections in good condition? Yes No KEY OFF. Battery terminals are OK. GO to QB2 . REPAIR battery terminals as necessary. QB2 INSPECT ENGINE COMPARTMENT FOR PROPER WIRE ROUTING
  • Inspect Electronic Engine Control (EC) System wiring for proximity to ignition components or wires.
Is wiring too close to ignition components or wires? Yes No REROUTE as necessary. Engine compartment wire routing is OK. GO to QB3 . QB3 CHECK KEEP ALIVE POWER (KAPWR) TO PCM
    Note: Refer to the PCM connector pin numbers in the beginning of this pinpoint test.
  • Disconnect PCM.
  • Measure voltage between KAPWR circuit at the PCM harness connector and ground.
  • While observing digital multimeter, grasp the Electronic EC harness and wiggle, shake or bend a small section while working from the PCM to the dash panel.
Does the voltage reading indicate less than 10.5 volts? Yes No ISOLATE and REPAIR open circuit. No open in KAPWR harness circuit detected. GO to QB4 . QB4 CHECK FOR REPEAT OF DTC P0603/P1605/P1633
  • Reconnect PCM.
  • Start engine and allow it to reach operating temperature.
  • Run Key On Engine Off Self-Test.
  • Retrieve Continuous Memory DTCs.
Is DTC P0603, P1605 or P1633 present? Yes No REPLACE the PCM. REPAIR other DTCs as necessary. If none, testing is complete.
Jun 30, 2011 | Ford Escape Cars & Trucks
The dv6775us Entertainment laptop was working. About 5 minutes after a shutdown, it wouldn't turn on. The light at the external power port and the charge indicator light in the front left corner come on...
Hello, If it a hard shutdown that you experienced, then, i should beleive that it is from the board. what i mean is that you have to change the processor of your laptop, then it will come back alive. But if it does not come back, you should know that the board has to be changed enterly.
Apr 08, 2011 | HP Pavilion dv6775us Notebook
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
04dodge ram air bag light goes off after starting then comes back
remove the battery cables and hold the positive and negative cables (WHILE NOT CONNECTED TO BATTERY!!!) together for about 2 minutes. This procedure will reset your vehicles KAM (keep alive memory) and will get rid of check engine/air bag lights as long as everything is connected properly
Aug 27, 2009 | 2004 Dodge Ram 1500
HP 1502 LCD Monitor Logo
60 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
