My new remote mouse for my note book will not light up. I replaced the batteries with new batteries and tried all combinations but the light would no go on.
  • 75 Answers
Is it under the warranty? contact the manufacturer. the best solution is replace it with new one... use the warranty right away before its expire. after you leave the store try to test it first to avoid inconvenience.
Posted on Aug 27, 2010
Cannot get curser to show on screen
This could very possibly be an issue with the sensor bar. Try these steps:
  1. First, ensure your sensor bar is plugged into the console and oriented properly! Take a look at this picture to see how it's supposed to be facing (NOTE: you will NOT see the purple lights even if your sensor bar is working!! These are ultraviolet lights and are not detectable to the human eye!) Click here for the picture.
  2. Make sure your Wii remote is on and has new batteries! Older batteries decrease the strength of the light that the Wii remote gives off that it uses to communicate with your sensor bar.
  3. Assuming these things work, consider increasing the sensitivity of your sensor bar. Directions for how to do this have been posted online by Nintendo here.
If none of this works, chances are there's something wrong with your sensor bar, Wii remote, or a combination of both. Replace the sensor bar before replacing anything else. If that doesn't work, get a new Wii remote. Good luck!
Mar 12, 2011 | Nintendo Wii Console
Does it need to have its battery changed? The light is out and it is no longer working.
Most likely.
It may be that there is no low battery light. Are the batteries replaceable? If so buy some new ones or grab some from another device (remote?) to test.
If they are special batteries, try ebay.com
Best of luck!
Feb 28, 2011 | GE Wireless Optical Mouse
My remote mouse just quite working
The first thing I would try is replacing batteries. Even if you think your mouse batteries are good, still try to replace them with the new ones.
If that does not work, try to reconnect your mouse by pressing the "Connect button"
Trying different USB port for the base - would be another option.
Feb 22, 2011 | Logitech 931307-0403 Remote Mouse
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
May 08, 2010 | 2008 Dodge Grand Caravan
Wireless mouse not working
You can use them both at the same time.Make sure the batteries are good.There should be a sync button on the bottom of the mouse.you need to check the wireless receiver to see if there is a button on there as well.If there is you need to push the button on there first,then the mouse.
The easiest way to fix a sticking key is to remove it from the keyboard and clean it out.Then replace the key.
Sep 02, 2009 | Dynex Optical Mouse
Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
Aug 10, 2009 | Computers & Internet
Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
May 04, 2009 | Toshiba Televison & Video
Key bord & Mouse Paid hang Acer Aspire 1642ZWLMi PC
Try to remove your battery first, battery can cause the mouse and keyboard freeze.
about the shut down problem, is it take long time to shut down, if it is, you should check your harddrive.
Mar 15, 2008 | Acer Aspire 1642ZWLMi Notebook
Targus mouse remote
If the Red Light is on the batteries should be good enough to function. Try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Feb 07, 2008 | Targus Wireless Remote Presenter Mouse
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
