Question about Maytag Dryers
I have a Maytag PYG2300AWW dryer and would like to know how to instal the glider clip that allows the tumbler to pass over it to reduce friction.
When I turn the dryer on it hums and the motor doesn't turn. Is there a capacitor on the motor that might not be starting the motor
Posted on Mar 05, 2012
Call maytag
Posted on Jul 12, 2008
The screws won't stay in the hinges on my Maytag dryer door, model #PYG2300AWW. It's like the holes in the cabinet are too big for the screws. Is there something else missing that they should be...
Hi ddyreson...
You are missing a sheet metal clip.
It will clip on the sheet metal with the large hole in it, to convert it from a large hole to a hole that you need to fit the screw...
Look around where you disassembled the dryer, it is somewhere in the area or in the dryer...
You can get replacement metal clips at HomeDepot,Loews,Ace Hardware,etc.
Please take time to rate me
Sep 05, 2011 | Maytag Neptune MDG5500AW Gas Dryer
What size gas connector do i need for maytag gas dryer pyg2300aww
The size where the nipple that ya connect to that sticks out the back of dryer is 1/2inch..now your gas pipe in the house could be 1/2" or 3/4" so in that case if it is 3/4 you would need 1/2" connecter at the dryer and a 3/4" by 1/2" reducer to connect at your house gas pipe
while i am all about the can do spirit... certain things that if done impoperly can blow up your house should be done by professionals that will do it correctly
Aug 24, 2011 | Maytag PYG2300A Gas Dryer
How to repair paddle inside drum paddle that fell off
To replace this "paddle" (It's callde a baffle), you'll need to access the outside of the tumbler (drum), by lifting the top.
Begin by removing the door. Remove the two hinge screws. You will then be able to rock the door and hinge out of the slot in the front panel. Next, remove the cover plates just opposite the hinges.
Now you can pull the front panel off the retaining clips and rock it downward, away from the rest of the cabinet. Once it clears the top, you can lift it off the bottom hooks. Just set it aside.
You will now see two screws (hex-head, 5/16 inch), just under the corners of the dryer top. Remove them and rotate the brackets that hook into the top. Removing the brackets will allow you to now swing the top upwards to expose the tumbler.
Just turn the tumbler until you can see the screw holes for the babble holding screws. You may get lucky and find the three baffle screws in the bottom of the cabinet. Re-install, check the others, and re-assemble the dryer in reverse order, and you're done!
Dec 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Repair loose tumbler fin
Pop the top, remove the front, the drum will come free. Take pictures of how the belt goes around the motor. Fix your "fin" and reverse.
The top is held down by spring clips.
Thanks for your interest in FixYa.com
a
Dec 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag performance pyg2300aww is making a screaching sound
HOW DO YOU CHANGE THE DRUM BELT ON MAYTAG DRYER MODEL PYG2300AWW
Nov 23, 2009 | Maytag PYG2300A Gas Dryer
Rubbing noise
Try checking the glide's under the front of the drum, the drum rest on the glide's to help it spin with little or no friction.
Apr 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer PYG2300AWW
If it acts that bad, I would try to find me a new dryer.
May 12, 2017 | Maytag Dryers
Broken belt that turns the drum
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Dryers Logo
348 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
