It dose not perform the drying process and the water does not drain out.
  • Washing Mach... Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Problems with a washing machine not spinning or not draining are often inter related..</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />If you are having a problem with your top load washer then check out this tip...<br /><br />Washing Machine does not Pump or Spin<br /><a rel='nofollow' href="http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin" target="_blank">http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin</a><br /><br />If you are having problems with your front load washing machine then checkout this tip...<br /><br />Front Load Washing machine not draining and or not spinning<br /><a rel='nofollow' href="http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining" target="_blank">http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Posted on Aug 27, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Aug 27, 2010
    Washing Machine does not Pump or Spin http://www.fixya.com/support/r4617986-wa...
    Front Load Washing machine not draining and or not spinning http://www.fixya.com/support/r4784376-fr...
    heatman101
Hello, i am using Haier washer dryer HWD-D1200TXVE that is 1 year old, after a full cycle (pre-wash) the machine gave an error 12 and did not perform drying because water was not drained. I opened the...
Look up the mfg website and see if they have a troubleshooting page or a support group. It may still be a warranty item check that as well
Oct 20, 2013 | Washing Machines
Trying to drain washer for move
Good Afternoon Jennifer, thank you for allowing me to assist you. I have located generic instructions on how to drain your washer, please follow the steps below:
1 Turn off water supply faucets.
2 Disconnect hoses from water supply and drain water from hoses.
3 Plug electrical cord into a properly grounded electrical outlet.
4 Add 1 gallon (3.8 L) nontoxic recreational vehicle (RV) antifreeze to empty wash drum. Close door.
5 Select the Spin Only cycle. Press Start and let the washer drain for 1 minute to drain out all the water.
(Not all of the RV antifreeze will be expelled.)
6 Press Cancel, unplug electrical power cord, dry off drum interior and close door.
7 Remove dispenser drawer. Drain any water in compartments and dry compartments. Replace drawer.
8 Store washer in an upright position.
9 To remove antifreeze from washer after storage, perform Clean System Cycle as described earlier.
I hope this information helps to some degree. If you have further questions, please do not hesitate to reconnect.
Jul 29, 2013 | Frigidaire FAFW3801LW Washer
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
WATER WENT INTO MY GEARBOX COMPUTER ON THE FLOOR ON RIGHT HAND SIDE THE GEARBOX DOES NOT CHANGE PROPERLY
First-remove the battery.Then clean the water draining plugs into vehicle bodie.Check with water for normal draining.If O.K. disconnect the gearbox computer and open the metal cover and left him to get dry.Then put all together and check the performance of the vehicle. Let me know
Jun 18, 2010 | 2000 Volkswagen Passat 4Motion
The water dose not stop running washer dose not drain. dose not aggitate
You could have an issue with your pressure switch. If it does not see a high level of water, it wont switch off the supply. Suggest you inspect the pressure switch plastic tube for holes or a leak.
Oct 23, 2009 | Kenmore Washing Machines
My fujitronic is leaking water. Any solution?
hi friend,
Instructions
  1. Step 1 Pull the air conditioner from the window on a mild, sunny spring day. The sun shine will help in rapidly drying out the air conditioner after you perform the next routine process.
  2. Step 2 Place the air unit on a firm surface. Preferably a concrete slab or a few old boards. Do not place the unit on grass or dirt.
  3. Step 3 Use the screwdriver and remove the outer metal housing of the air conditioner. There are generally 4 to 6 screws along the lower edge of the cover that holds it to the frame.
  4. Step 4 Observe the inside of the air unit. Note that there is a plastic drain tray on the bottom. This drain tray carries away the condensation water from the cooling coil and allows it to flow to the outdoors and drip to the ground. The drain tray is plugged from last seasons collection of dust and bacteria growth.
  5. Step 5 Use the cup measure and pour some house bleach into the plastic tray. Allow the bleach to "work" on the nasty solids that have collected there for about 5 to 10 minutes.
  6. Step 6 Connect the gardenmag-glass_10x10.gif hose to the outdoor spigot and attach the spray nozzle to the hose.
  7. Step 7 Spray in the interior of the air unit with the moderate pressure from the spray nozzle. Force the water into the plastic drain tray and remove all of the solid debris that is laying there. Spray the interior and exterior coils as well since you have the unit cover off. You will have to remove the interior filter as well. Clean the filter while it is exposed.
  8. Step 8 Place another cup of bleach into the plastic drain tray and allow the liquid cleaner to set for about 5 to 10 minutes than thoroughly rinse the unit with fresh water. The inside area should be thoroughly clean.
  9. Step 9 Allow the unit to completely dry in the sun. When dry, replace the exterior cover and place the unit back into the window. The unit will be cured of leaking for another cooling season.
Tips & Warnings
  • Weekly cleanings of the interior filter will help in alleviating bacteria build up in the drain tray. Living in an outdoor dusty environment may create the need to perform the bleach cleaning more than just once a year
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Fujitronic FA-1300 Air Conditioner
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Mar 19, 2008 | Equator EZ 3612 CEE Front Load...
Dishes stay wet after cycle
No drain hose routing has nothing to do with drying performance. The biggest thing that affects drying performance is water temp. Modern dishwashers use such a small amount of water is usually never gets very hot before the dishwasher has reached its full level. You can try to select hi temp wash and that should help. Also make sure that heat dry is selected. Also you really to purchase jet dry and install in dispenser. This will improve drying as well.
Dec 01, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwasher dose not drane
YOU CAN TRY REMOVING THE LOWER RACK AND LIFT OFF THE SPRAYER. THE DRAINAGE WHOLE IS USUALLY VISABLE. YOU CAN FLUSH OUT THE DRAIN TO SEE IF THAT DOES IT. THERE SHOULD BE NO STANDING WATER IN THE BOTTOM OF YOUR DISH WASHER AFTER WASH CYCLE AND DRY CYCLE. HOPE I COULD HELP.
May 02, 2007 | Hotpoint 24 in. DF55 Free-standing...
Washing Machines Logo
Top Washing Machines Experts
