Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I am looking for amana magnetic door seal - Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
  • Amana Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Yes, that is not that hard to fix and you can easily buy the parts yourself online...<br /><br />Here is a tip that will help you with the online buying...<br /><br />How to Buy Appliance Parts Online<br /><a rel='nofollow' href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online" target="_blank">http://www.fixya.com/support/r3907570-buy_appliance_parts_online</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Posted on Aug 27, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Aug 27, 2010
    How to Buy Appliance Parts Online http://www.fixya.com/support/r3907570-bu...
    heatman101
What is a magnetic seal on a refrigerator door?
Its strips of magnet on the parts of the door and the part of the inner frame of the fridge that hold the door sealed with magnets nice tight seal.
Sep 05, 2014 | Amana Refrigerators
Amana TH18v2wReplace door seal
Changing a door gasket on a fridge is one of the most aggravating repairs in my opinion. The best advice I can give on this is make sure you take the door off, do not remove the screws all the way, just loosen then as needed, and heat the new gasket to make it pliable when you put it on the door. Hopefully you machine is one of the ones that has a magnetic gasket so you can just peel the old on off and throw the new one on without a problem.
Jun 21, 2012 | Amana Refrigerators
Water drops under top door always!
That is strong indication that the magnets inside of the door gasket(s) are weak and aren't holding tight to the door to seal it. The door gasket(s) need to be replaced.
Gene
Aug 05, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I installed a new magnetic seal on my Amana refrigerator. The new seal has been sitting in its box for about ten years. After installation, I realize it has lost its magnetism. Can I rejuvenate it somehow?
No. Never heard of this happening. Make sure that the door stop at the bottom hinge is not bent and keeping the door from shutting all the way. I've seen this alot. Also, if you soak the gasket in hot water for 15 minutes or so, it will soften it up and lay flat when you install it.
Feb 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Right hand door pops open when closing left hand door
The dool seal is not sealing completely on your fridge door . Maybe pulled in corner , split somewhere . If looks ok , then magnetic portion is not sealing against cabinet somewhere . Once you find the area , use a hairdryer to soften the rubber while door closed and it will pull itself down due to the magnet .
Jul 18, 2009 | Refrigerators
Amana ATB1832ARQ Top Freezer Refrigerator - Freezer door not seal
OPEN THE DOOR WIDE . YOU SHOULD SEE THE HINGES THAT SUPPORT THE DOOR. LOOSEN THE SCREWS THAT SUPPORT THE DOOR----JUST LOOSEN , THEN LIFT UP ON THE DOOR AND TIGHTEN THE SCREWS. NOW YOU CAN LET GO OF THE DOOR. I HOPE THAT WORKS FOR YOU . GOOD LUCK.
Apr 19, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Door seal
i wouldn't worry about vacuum seal. door gaskets contain a low powered magnet around the entire face for "contact" seal, id look into perhaps something placed on one of the shelves or door blocking the door from closing as tightly as you remembered. if you have a problem with that gasket. it would have to be physically ripped and where it didn't make contact you would have an influx of warm air resulting in ice balls forming inside door liner adjacent to seal
Mar 03, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
