Question about Intel D845GVSR Motherboard
My cpu is intel mercury chipset 845 mother board but did not getting started, smps ok i already cheak and processor fan ok but its not getting started wht is the problem plzzzzzzzz help me any one
Processor
Posted on Aug 27, 2010
Hai, my pc mother boaed cd had lost, i want mother board cd to downloadf or System Model: D845GVSR,and Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz, how can i solve this proplem
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+845+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D845GVSR
Sep 03, 2011 | Computers & Internet
My machine is not starting..CPU fan stops just after starting for 3-4 sec..I am sure that the CPU,RAM and SMPS are OK.Most probably the problem is in the MB.Kindly help me to solve the problem.I am using...
if your power supply is good and has DC output.....i have encountered a leaky capacitor at motherboard near the power supply connector socket...need to replace it esp. if it manifest bulgy appearance..it is a electrolytic type, replace w/ same value, it does affect the power to supply the MB due to fluctuation......try to test run after replacing it..have a nice day...
Feb 12, 2011 | Mercury P4VM800M7 Motherboard
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
Mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
May 30, 2010 | Mercury P4VM800M7 Motherboard
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Problem Regarding Booting
due to the increase in temperature inside the cpu for the protection of the motherboard and components it might not be getting started ..
this happens if the processor fan is not running properly or if it stucked due to some dust or obstacles ...
try cleaning it after separating heat sink and processor ....
after refitting the processor trying booting it should work ....
if needed replace the processor fan ..
regards
-Dileep
Nov 27, 2008 | Intel D845HV (735858149143) Motherboard
CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
Jun 19, 2008 | Intel D845GVSR Motherboard
Booting Problems 845 GVSR Chipset Motherboard
it is possible to repair,just check the rate if it is costly then you better take a new one
May 15, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
