Question about Genius GH 4080 SE 8-Port Ethernet Hub (GH4080SE)
Do we need a driver to set up the connections of pc's to a GH 4080SE hub?
  • 75 Answers
No. You do not need a driver
This diagram illustrates use of an Ethernet hub or switch on a home network. See below for a detailed description of this layout.
Posted on Aug 27, 2010
Testimonial: "really appreciate your help to set up my network. Thanks"
  • Adamprince
    Adamprince Aug 27, 2010
    Key Considerations - Ethernet hubs and switches allow multiple wired computers to network with each other. Most (but not all) Ethernet hubs and switches support up to four / eigth connections.
    Optional Components - Networking of Internet access, printers, or game consoles and other entertainment devices is not required for the rest of this home network layout to function. Simply omit any of these components shown that do not exist in your design.
    Additional hubs and switches can be incorporated to the basic layout shown. Connecting hubs and/or switches to each other expands the total number of computers the network can support up to several dozen.
    Limitations - All computers connecting to a hub or switch must possess a working Ethernet network adapter.
    As shown, unlike a network router, Ethernet hubs and switches cannot interface directly to an Internet connection. Instead, one computer must be designated as controlling the Internet connection and all other computers access the Internet through it. Internet connection sharing software can be installed on each computer for this purpose.
    Networking Diagram
I got a behringer c-1u mic and I plugged my USB in the pc and it says no drivers are installed for this device and also the green light of the mic flashes soon as u connect it then dims out and stops...
Either you haven't yet installed the drivers (usually a CD that comes with - or can be downloaded from Behringer Website),
AND/OR your bios settings dis-allow plug-and-play USB devices. Restart your PC and enter Setup to check..
AND/OR your microphone is bad, have you had success with it on another PC?
AND/OR your USB Port is bad - are you plugging directly into the PC's USB, or a seperate multi-port Hub? I once had a multi-port USB Hub that burned up anything I plugged into it.. Took me about 3 devices to die before I simply changed the hub. Pwoblem solved..
Hope this helps...
May 03, 2012 | Computers & Internet
My frontman wireless guitar does'nt syn
1. You need 3 other controllers besides the Nyko guitar (they can be the rockband instrument set, or just any PS3 controllers. I used a DS3 a RB guitar and GH3 guitar)
2. You need all 3 of the controllers assigned to the PS3 taking up spot 1-3 except the Nyko guitar (goal is to assign the Nyko to 4 or higher)
3. Plug in the Nyko dongle and attempt to link with the guitar (it will most likely make the Nyko button turn red which is the color that won't play)
4. Turn the switch on the dongle back and forth once or twice ending on GH setting letting the guitar link on it's own (It may not assign correctly on the first try, but keep switching between Rockband setting and GH setting. Always end on GH, because it will work with Rockband on GH setting)
5. After a few times it should link and allow you to play
Problem is the firmware of the PS3 (V3.10 or higher)
Dec 27, 2010 | Nyko & FrontMan Wireless Guitar Controller...
Conflict message
if u have 2 PCs connected to the hub/router then you must specify the IP address in Network Connection wizard..../ LAN properties / TCP-IP setting Tab......set each PC different....IP address
say like this.....
192.168.1.3 for 1st PC
192.168.1.5 for 2nd PC
the rest of the settings is based on you internet service provider
this will work....
Jul 15, 2010 | NetGear EN104 Networking Hub
How can I connect my hsm mic to gh3 world tour?
You can use any mic that has a usb plug, you can also use the usb mic on your pc too. You will not be able to the mic with GH3, because GH3 does not offer band multiplay, you will need to get GH World Tour or a GH track pack. You can also use the guitars from GH for all the Rockband series too. So having the mic already, all you would have to do (if it has the usb) is connect it to the usb plug in the front of your console. I assume your using the PS2 b/c of the pic. You can also use the drums and mic from PS2 with a PS3. You can't use the guitar from PS2 for PS3 unless you buy this wire that converts the controller plug to usb, on ebay they are $4-$5, obviously a lot cheaper than buyer another guitar @ $40-$50. This info should help and may answer some future questions as well. Good luck.
Mar 01, 2010 | Disney Interactive High School Musical:...
Idont know how too setup this router
is this a hub or a router??...
if it is a hub you dont need to set it up....but if this is a router you need a driver..but remember some router usually dont have driver if they dont have wi-fi....
just connect your pc and connection to it and uit runs automatically...
rate me..
Feb 06, 2010 | Acer ALH 508D (91.AB849.001) Networking...
I CANT GET CONNECTED TO BT HUB
have you typed the key exactly? viz uppercase/lowercase. The switch(hub) might have MAC address filtering on. also check if the switch(hub) has a DHCP running, which allocates IP addresses, if not you need to set your wireless connections IP address within the same range as the switch. If all else fails attempt to connect the switch via a utp network cable which should have been suplied with the switch(hub) so you can access the switch and make the necessary changes... email me on djtracer@vodamail.co.za should you need more info.
Aug 11, 2009 | Computers & Internet
PC does not recognize Lumix DMC-TZ5 as USB device
I contacted Panasonic and here is what they told me to do and it worked.
"No additional drivers are needed as it runs off the USB drivers imbedded in
your Windows OS. That being said though, it is not that the USB ports on the
front of your computer are faulty, just that they are in fact a HUB and not
the port which is located on the back of the PC. Windows does not
traditionally like reading external Hard drives (your camera becomes one when
PC connect mode is selected) through a HUB. In this case I would still
strongly recommend connecting to the back of the PC."
Aug 30, 2008 | Panasonic Lumix DMC-TZ50 Digital Camera
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Pano mgnetwork?
gud pm keanne...hmmm here's my suggestion:
1st u need to buy 8-Port Hub/Switch
NIC or LAN Card
7 pcs UTP Wire w/ RJ45 Jack on both end (depende sa haba)
Then connect smartbro to the CPU (Built-in LAN)
Connect 8-Port Hub/Switch to the CPU (LAN Card)
Install Hub/Switch Driver (If Needed)
Connect the 6 PC to the Hub/Switch
Setup your network using Network Wizard (Control Panel)
goodluck...
Jan 29, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Genius GH 4080 SE 8-Port Ethernet Hub (GH4080SE) Logo
133 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
