Question about AOC Computers & Internet
Upon turning on PC a moving placard gets on screen which says "Input Not Support" and constantly moves all over screen. How to remove? Wha tdoes it mean?
  • AOC Master
  • 11,800 Answers
It means that the signal that comes to the monitor is in a format that is not supported by the monitor. Get another cable and reconnect the monitor to another port on the video card.
Posted on Aug 27, 2010
Why the HP flashes upon entering the room, as motion detector do
THAT'S IS THE MONITORS MOVING-SENSOR YOU CAN TURN
IT OF IFYOU WAN'T
Mar 09, 2015 | HP Computers & Internet
I have a Lab 330 that the towner arm will not go down. I have moved and locked it in the cradle for the move. No the lever is not stuck up. The turn table turns fine. But the arm will not go down. Wha
Tonearm placement is synchronized by the mechanism beneath the turntable so it will be necessary to remove the platter to expose that mechanism to make repairs.
Feb 08, 2015 | Audio Players & Recorders
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
When I turn the monitor on I get a message "In
Most Dell LCDs have multiple inputs and they will go into "standby" while waiting for a signal from your PC. This happens when your PC goes into "sleep" mode or if you are sure your PC is not in "sleep" mode then usually the LCD is not in the correct input selection. Check the input selection for the appropriate input. As always, make sure the cables are securely connected. Hope this helps.
Jun 15, 2011 | Dell E173FP 17" LCD Monitor
A warning light a motor with the word check in it , wha tdoes it mean?
This means that there is a problem with your engine and the computor has logged a "fault". You will need to take your car to a mechanic who can access the computer and read the fault code to find the problem.
Apr 30, 2010 | 2000 Daewoo Leganza
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Steering wheel gets stuck
2007? It's most likely still under warranty. Take it in to a Hyundai Service Center. It's probably the 'limit' switch which is malfunctioning.
May 01, 2009 | 2007 Hyundai Veracruz SE
My laptop screen became pink some pixels are moving
When a laptop screen turns pink it is usually due to a loose or faulty ribbon cable from the screen to the motherboard. If replacing that does not help then the problem is the inverter.
Apr 26, 2009 | Computers & Internet
"input not supported"
what you may need to do is find an accepted screen resolution, as your screen is 19" widescreen and your notebook will be set for a normal monitor display, so either try the auto button on the screen or look at the properties of your graphics card om the notebook to find supported screen resolutions for extended displays.
Aug 28, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
113 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
