Question about Acer Extensa 4620 Notebook
The laptop screen freezes and fades out slowly becoming darker and darker. Moving the screen however helps restore it back to life for a short while
  • 6,831 Answers
Hello
Ok, because the screen gets better for a little while if you move it, this might just be a simple connection problem. The thing is, and it is quit common on notebooks, is that the data cable linking the screen to the motherboard sometimes get a little loose. Hence, the screen still works, but not properly.
I would suggest that you open up the unit and just make sure that the data cable is plugged in correctly. If you do not feel comfortable doing this yourself, you can take it to your nearest computer repair shop.
Hope this can be of help.
Kind regards
Andrea
Posted on Aug 27, 2010
Using the contol buttons on front panel
You did not give a lot of info in this.
was the monitor old (many year) did it happen slowly or not.
is it even on all surfaced or darker on one side?
faded : no contrast or darker?
From the point vue I get, seem to be the neon lamp one maybe shot or not working a 100%
with year, the neon lamp loose brightnest. they even get yellow a little bit (if you compare a new monitor with an old one (white area) the old always fade in the yellow. )
Jan 03, 2014 | Dell Computers & Internet
Toshiba e studio 250 The print is comming out partially faded. The tona is full, so I am not sure what the problem is, any ideas please? Thanks Anuja
Hi
It might be one of the part life had ended like fuser drum unit life ends or transfer belt unit life ends. Try to check this parts in the LCD screen in LAN setting. or PART LIFE. See if how much percent is their life parts.
Replacing this parts would normal bring your print out to good printing.
Or adjust the contrast setting in the control LCD menu screen to darker setting to make print out more darker.
Jun 22, 2011 | Toshiba E-Studio 250 All-In-One Laser...
Screen had slowly grown darker. Is now
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Laptop Screen Freezes and turns black When Adjusted angle.
It is possible that the video cable is chafing in the point where it passes through the hinge assembly. Try reseating the video cable, if that doesn't help, the replacing the LCD cable assembly is the likely fix.
Dec 05, 2009 | Dell XPS M1530 Notebook
I require the SNID for an acer and the label is faded.
hiya my compaq pescario laptop keep crashing/screen freezes.my word document is corrupted+ it wont let me delete anything.can sme1 help please
Dec 02, 2009 | Acer Aspire 3000 Notebook
Drink split on keys, now has fading to white screen. big problem.
Well if the motherboard is replaced, it is probably a problem with the laptop monitor. If this is the case, at this point, it's probably cheaper to buy a new laptop.
Oct 22, 2009 | Dell Inspiron E1705 Notebook
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
42 inch samsung lcd tv darker on one side
Its one of two things, bad lamps in the panel or bad Tcon board
Dec 24, 2017 | Televison & Video
Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
Jun 19, 2009 | Compaq Computers & Internet
Inspiron 6000 black screen
I think your talking about your screen fading out.
This is normal. LCD screens do slowly fade out over time. They have a life span.....If this is indeed the problem, then you have 2 choices.
1) Get the screen replaced.
2) Get a new laptop.
My advice would be getting a new laptop as the prices are getting lower every day. Most likely this is the cheaper option.
Dec 27, 2007 | Dell Inspiron 710m Notebook
Acer Extensa 4620 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
