Question about Vulcan ERD85 Deep Fryer
My vulcan fryers pilot keeps blowing off. ther e are 2 pilots and one has the problem. pl help
  • Vulcan Master
  • 43,501 Answers
The thermocouple that senses the flame is bad... on most deep fryers they are actually "power pile generators" they produce a bit of current from the flame hitting them and the current operates the gas valve...
Replace it and you will be operating again they do wear out regularly...
heatman101
Posted on Aug 27, 2010
Need to know where to light pilot
Normally, it's under the fryer, inside the door...The issue almost always is you have to press the button down long enough for the sensor to tell the fryer to light....There are 3 or 4 burners in the bottom of the frypot on top and under the fryer is the pilot to light these all up...Look for the gas valve, turn the gas valve to pilot, and press and hold it down, put flame to pilot and release button when flame is self standing... Then turn to on position. If you have other issues, call the Vulcan company themselves, and they will help you further.... Susan Restaurant Equipment Outlet, Cinc, Oh www.restaurantequipmentinc.com
Aug 20, 2011 | Vulcan EF3 Deep Fryer
I have a vulcan fryer and i can light the pilot then i turned on the flames it came on then went out and would not come back on the pilot stayed lit.
Sounds like thermostat is bad... Vulcan also recommends on replacing the high limit as well.
If you have further questions, call Vulcan directly and they will direct you to a dealer that sells their parts... Their number is 502-778-2791. If I can help in any other way, call me at 888-542-5959, Restaurant Equipment Outlet, Cincinnati, OH and our website is www.restaurantequipmentinc.com
Aug 13, 2011 | Vulcan EF3 Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
Pilot light on thermostat click main burner doesn;t come on
Don't know if the pilot has been cleaned or the thermopile has been changed. The pilot being lit can be good to keep valve open but not strong if enough to open main burner. If after checking all the above, make sure you have gas flow from the valve, if so replace thermostat.
Apr 01, 2011 | Vulcan EF3 Deep Fryer
Pilot light will not stay lit as soon as you let off the gas valVE arm it will go out. vulcan model TK 65
1. Check to make sure you have continuity across the high limit terminals.( you can use a jumper wire for testing) Unit operates on about 1/2 of 1 volt so no worry of a shock. 2. Check to make sure your pilot generator is producing over 500 millivolts. Make sure the pilot orifice is clean and that you have a nice sharp pilot flame heating the pilot generator.
Tom
Aug 03, 2010 | Imperial IFS40 Deep Fryer
Pilot won't lite. fryer is 6 months old. Did get pilot to lite once and as soon as we turned thermostat pilot went out.
When you turned on the thermostat you required more millivolts from the system and it failed. Low millivolts. That would tell you the pilot generator needs replacing. Make sure you have a good pilot flame hitting the pilot generator.
Tom
Jul 07, 2010 | Vulcan EF3 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Watermark Grille pilot prob
Your question is posted under vulcan fryers but the comment refers to a grill. Either way, I think your problem is gas pressure and/or supply related. You may need a new regulator, you valve may not be open all the way or any quick couplings you may have are not coupled completely or are faulty. What is happening is there is enough pressure to keep the pilot going, but when the larger route for the burner gas is opened the gas is quickly used up without proper resupply. A regulator installed backwards can have this same effect. Hope this helps
Oct 17, 2008 | Vulcan GR45 Deep Fryer
Vulcan Deep Fryer Need to Light Pilot
you have to hold the knob in after pilot is lit for at least one minute
Jul 09, 2008 | Vulcan EF3 Deep Fryer
Vulcan ERD85 Deep Fryer Logo
78 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
