Plus paper folder F500 manual - Office Equipment & Supplies
Since upgrading to windows 10 I am unable to scan. Message Is Unable to write the file to this folder. Please make sure you have correct permissions to write to this folder. (CC3-107-00431005)
That sub folder is in a windows protected folder. See if you can create a folder un your libraries subdirectory and name is scanned docs. Then tell the scanner to send it to that folder
Aug 12, 2015 | Brother MFC-7420 Laser Multifunction...
How do you manually feed legal paper into a HP laserjet 4 plus (model 2037A)? It only has a letter paper tray. I inherited it without a service manual
The LaserJet 4 plus I have worked with had a paper tray that was adjustable for letter or legal. If yours is not, there should be a door on the front of the printer that will pull down at the top, and is hinged on the bottom. Open the door, you will be able to extend the "paper tray" and put a small amount of legal sheets on it. Go to the menu and tell it to print to this paper tray, I believe it is paper tray one.
Aug 02, 2013 | HP LaserJet 4 plus Printer
HP LaserJet 4 Plus printer, as the paper is starting to feed into the printer from the MP tray the paper on the left side pulls in crocked and therefore causes a paper jam. Pick up roller and seperation...
There is something blocking the paper path.(Like a paper clip or something). Remove the toner cartridge first, then use a file folder or thin cardboard to push the object out of the way. Put the toner back in and try printing again. Good luck !
Apr 03, 2013 | HP LaserJet 4 plus Printer
My samsung sgh-f500 always restart upon opening my cell then continous restarting what will i do
my samsung sgh-f500 always restart upon opening my cell then continous restarting & keypad not working at this time what will i do
Jan 08, 2010 | Samsung SGH-F500 Cellular Phone
My sound isn't working
Make sure mute isn't on in ANY way. Make sure your keyboard doesn't have a mute and the volume control is ALL the way up. Make sure too that you are on the correct sound device.
Once i selected a Screen device for a sound device by accident and i was freaking out. I did all the steps I told you above and I figured it out xD
Hope this helps you!
Oct 19, 2009 | HP Compaq Presario F500 F700 and G6000...
I have a fax machine the No. is KX-F500 i lost the
You can download the manual here for free. The instructions you need are on page 8.
Aug 23, 2009 | Panasonic KX-TG5633BP Phone
I am having problem w/ saving a document to hard drive
Need more info, can you save as a .txt or .rtx ? Have any other problems with saving to the drive? Have you tried to-- save as-- and put your doc in a new folder or rename the doc?
Jul 16, 2009 | HP Compaq Presario F500 F700 and G6000...
HP Photosmart 2610
hmm..you may need to remove that premium plus option, through the system preferences folder. Then re install the drivers(get em here for updates) for the Inkjet printer. And be sure to only select the features you really want.
Mar 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
637 people viewed this question
jasbo
jasbo
