Question about Krups Espresso Novo 2100
The hard plastic gasket that fits 1/2 of the seal has fallen off - I can manually put it back in place each time I make espresso, but it doesn't always stay in place. How can I get a replacement?
  • 490 Answers
Here is the contact info for the authorized Krups parts vendor. I was not able to locate the exact part as the number off the bottom of the machine is required. They should have no problem getting you a new gasket. Hope this helped some:)
Posted on Aug 27, 2010
Do you know where can i find the rubber gasket that goes around the brew head of my Cuisinart EM 100 espresso machine ?
It sounds to me that your group seal is bad. Since this machine is a 15-Bar unit, it puts out quite a bit of pressure causing water to leak out around the portafilter when making espresso if your seal is old or damaged. The pressure doesn't build up as much when you are running just water through the machine - hence the reason why the machine works ok without grounds. I sell a LOT of parts and accessories for various manufacturers of espresso machines. This particular seal is extremely difficult to locate fom Cuisinart, but is rather easy to replace. Through extensive testing, I have located a replacement gasket produced by another major manufacturer that fits the Cuisinart EM-100 & EM-200 machines perfectly. I sell them for $10.99 each (or two for $19.99) which includes shipping in the continental US and I accept Paypal. If you would like to contact me via email (cowboy_romeo@yahoo.com), I will be happy to help you out.
Mar 20, 2012 | Cuisinart EM100 Stainless Steel Espresso...
I need a replacement Carafe for Back to Basic CC5500 coffee maker
If the leak is in the seal between the metal center which sits over the warmer and the plastic surrounding it, disassemble it by removing the screws holding the metal to the plastic. Remove the metal center and the silicone gasket. carefully clean the sealing surfaces of the coffee residue on the metal and the plastic and both sides of the gasket, use detergent in hot water, scrub it if necessary and also use some ammonia in the wash water if needed. Thoroughly rinse the cleaned parts with clean fresh water and let it dry. When dry wipe the surfaces with a sturdy paper towel wet with rubbing alcohol to remove any residue from the water.
Glue/seal it together with a silicone caulk which says somewhere on the tube that it is OK for aquariums or one that DOES NOT have any biocide or anti-fungus or anti-mildew additives, they are usually not good for food preparation utensils like your coffee carafe.
To seal it, remember the caulk is very sticky and will make a real mess if you get it where it is not supposed to go, so be very careful and use the minimal amount to leave narrow bead of caulk on both sealing surfaces on the plastic and the metal pieces. It is easiest if both sealing surfaces are placed on a sheet or two of newspaper on a conveniently situated counter- top or work bench. When you are satisfied that there is a narrow bead of caulk ALL the way around the circumference of the sealing surfaces, VERY carefully align the gasket's straight length (about an inch) with the mating surface on the plastic part which is attached to the glass. Gently press the gasket down to the caulk after double checking to make sure it is aligned with the shape of the sealing groove. Now you are ready to place the metal piece on top of the seal, again making sure the straight part of the seal is aligned with the seal you just placed on the glass/plastic part of the carafe and the holes on the metal base align with the holes in the plastic/glass part too. When all is aligned, push the metal piece toward the plastic/glass carafe part until some caulk oozes out and the pieces are close enough to start the screws. Be very careful when starting the screws to make sure they are in the same screw threads, since plastic is MUCH softer that the steel screws, they can cut new threads and then may pull out or not be able to be tightened. to make sure the screws are in the original threads, place the screw in the hole, turn it BACKWARDS up to one full turn, until you hear it click into the original screw thread or feel it drop into the thread. then you can screw it in only a couple of turns. To make sure not to warp the base or damage the plastic bosses that the screws are going into, after starting all the screws, screw them in one by one a few turns at a time going around the circumference of the metal by opposites (if six screws, screw in this order, 1 - 4- 2 - 5 - 3 - 6, then back to 1 and start all over) until the plate is screwed down and the caulk as oozed out all around and the screws are fairly tight. Again the plastic is weak, so you need to screw the screws in firmly, but not too tight. If you are using a jewelers screw driver, it is hard to over tighten the screws, because the screwdriver is so small. This was the hard part, now let the carafe seal cure for 2-3 days, longer if it is very low humidity, since the silicone needs moisture to cure. When cured, the excess silicone caulk can be trimmed off with a sharp knife or single edged razor blade or a utility knife with a sharp blade and the pot should be ready to go. to leach and flavor from the sealant, run a few pots of water through the beast...
If your "sneak a cup" valve is leaking, like ours, try this, take a utility knife and cut the screen out, clean the surface of the tube between the inside of the pot and the valve as best you can. Go through the same cleaning procedure as for the gasket. You will probably have to remove the valve mechanism to do this, note that the third screw holding this valve in is under the handle, which must be gently pried apart to access it. when all is clean, including the valve gasket and the plastic valve mechanism, put it back together. Then fill the space between the valve gasket and the inside of the carafe, where the screen was with silicone caulk, until the caulk completely fills the hole to overflowing. After it cures, in a few days, trim it as best you can flush with the bottom of the carafe. Then run a few pots of water through before brewing any coffee. Hopefully, the leaks are sealed and you have coffee pot that doesn't dribble all over the counter...Have fun!
Jan 11, 2012 | Back to Basics CC500 12-Cup Coffee Maker
My Krups XP4000 Espresso Machine has never been used. We tried to give it a try yesterday and it appears the pump doesn't work. You can hear the machine trying to do something but no water comes...
The pump is probably bone dry, you will need to put some water into it under pressure. I have a piece of hose in my workshop that fits the seal that the tank engages into, it's about 8 to 10" long. I engage the hose, fill it with water, activate the pump and seal my mouth over the hose and blow as hard as I can like I'm blowing up a balloon, it rarely fails.
Nov 16, 2017 | Krups XP 4000 Espresso Machine
How do you release the brewing head after removing the two allen bolts pleasse? It needs cleaning and I have a new seal to fit.
  1. release filter bolt
  2. remove filter
  3. release& remove the alien bolts in filter holder
  4. push it from side with screw deliver, you don't have nothing attached, it will come down
  5. once filter holder is out you clean it good specially the 4 holes in sides
  6. While removing the old seal you might need to be bit rough, to cut the seal if it is too hard and non elastic at all anymore.
  7. clean it good and brush the place of seal
  8. take the new seal with numbers(mark on the seal) up and put it in the place so that numbers are going up to group
  9. push it with hand a bit
  10. get the portafilter without filter
  11. and put it in left teeth >>> roll a bit like when you put it in place
  12. do the same with left one
  13. repeat action in both teeth and with filter
  14. Control the seal, if it fits good in place.
  15. Assemble everything back and drink one espresso as an reward for work.
Mar 01, 2011 | Gaggia Classic Espresso Machine
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Gasket - coffee grounds in coffee
    hi! It goes on the top and surrounds the pin that pops the hole in the kcup....the problem I'm having is how do you stick it on? Should we use crazy glue?
    Apr 03, 2010 | Keurig B70 Coffee Maker
    The portafilter basket leaks out the sides no matter how firmly held in place or the quantity of coffee in the basket
    Hi
    You need to replace the brew head gasket. It becomes hard and will not seal. Order 2 gaskets because 1 always fails on Friday before a big party on Saturday.
    Nov 29, 2009 | Pasquini Livia 90 Espresso Machine
    Half of the time, espresso leaks (or sprays) out of multiple points on the handle/portafilter, instead of coming out of the two designated holes. Almost as if too much pressure builds so it gets forced out...
    Try running water only and see if you get the same result. If you do, then soak the filters and the bottom of the metal basket of the portafilter holder in vinegar (distilled white). In my experience, this unit requires constant cleaning. But the espresso is good.
    -Tha Mp3 Doctor
    Jan 12, 2009 | Cuisinart EM-200 Espresso Machine
    Saeco Royal Exclusive expresso
    hello you say sometime water leak out normally when the water valve seal is defective it will always leak. look under the water tank you got 4 plastic guide moulded in the container make sure no guide broken or missing a little pease of plastic if you got a pease missing add whatever missing inthe hole like a shim check it out cheers
    Jan 11, 2008 | Saeco Royal Exclusive 30153 Espresso...
    Krups Espresso Novo 2100 Logo
    109 people viewed this question
    Top Krups Coffee Makers & Espresso Machines Experts
    Billy Mac
    Ross Keen
    Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
