Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Both, top freezer and bottom frige are warm the compresser is not working,evap fan runs,tried bypassing thurmostate,nothing,inside the freezer theres a canister cliped on the coiles with infinite resistence is this the defrost coil
  • Whirlpool Master
  • 1,606 Answers
2319792 is the part number for the overload/relay , which plugs onto the side of the compressor . This part makes the compressor run , and is easily replaceable .
Posted on Aug 27, 2010
  • Mike Smith
    Mike Smith Aug 27, 2010
    The canister is the defrost bimetal , has nothing to do with compressor running , only heater when in defrost . Thermostat is good since fan is running .
  • Whirlpool Master
  • 17,130 Answers
Switch off the fridge for several hours.. 6 hours. then switch on and check if ice forms in about 2-3 hours in the normal setting. If there is no cooling at all with the compressor running then it is possible that the gas is low or the compressor is faulty with low pumping pressure. get help to estimate and decide.
If the compressor is cooling initially but after several hours it is dropping , open the freezer panel to check for frosting. If so then the defroster is not working.or the thermostat is not cutting off the compressor,
check individually to confirm.. defrost timer, thermostat or heater.
I have an amana ASD2626hes side by side refer/freezer unti. REcently it soppted colling in the refer and the freezer was cold on the bottom only - top warm. I pulled the freezer inside coer - found the...
It could be either....
It is best to check and see if you are getting power to the fan...power to fan, the fan is bad...no power the board is bad...
heatman101
Apr 23, 2011 | Amana Refrigerators
The freezer is COLD..freezes solid. Setting at low. The frige part is not cold and is set at high. Seems everything is going up to the freezer. Unit is just over 1 year old. Drinks are cool but not...
where is the freezer on top,side by side or the bottom.all a fridge does is blow cold air from the freezer to the fridge side that's it,if the fridge is warm there's a problem most likely in the freezer,a plugged drain or when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,also check your warranty it still might be covered.send the model number and i can help you,if you see water under the bottom draws or in the fridge section if the freezer is on top you have a blocked drain in the freezer.let me know what you find and i can help you
Feb 20, 2011 | Magic Chef Refrigerators
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Freezer frozen on bottom and frige cold on bottom only. No airflow coming from vents inside freezer or top left of frige, freezer and frig warm at the top. Model is a ED25QF
check to see if fan is running in freezer if it is you may have a defrost problem if not replace the fan its the evaorator fan that is in the freezer
Mar 08, 2010 | Whirlpool ED5FTGX Side by Side...
Top refrigerator not ccoling and bottom freezer
check the condenser temperature when the compressor is running by hand it must be warm or hot if it is not then that means no refrigerant left in the system.This can be a possible cause.
Sep 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool top freezer bottom fridge
check if compressor is running if no check thermostat , bypass thermostat if comp starts change thermostat. if comp does not start call repair man as comp will have to be changed, major operation.
If comp is running OK then check evap fan motor
Oct 16, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Warm fridge
If this Amana has digital display at top in fridge more than likely the Jazzboard (control board) has failed. Check for votage at fan if you don't get any or some times if you do the Jazzboard can still have issues controling the evap.fan. I've found the Jazz board to go bad some times. Hit me back let me know. Jazz board is in the control box were the digital numbers light up.
Jan 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
