Question about Kitchen Ranges
My old freezer is fairly warm on the outside walls over about 20% of the area. Is this normal?
  • Kitchen Ranges Master
  • 43,501 Answers
Yes, this is normal, on some of the freezers that are old the coil to disapate the heat are inside there...that is what you are feeling..
heatman101
Posted on Aug 27, 2010
Is it normal for warm air to blow out of the fan at the top of a side by side sub zero. Its over 20 years old and we recently had the compressor replaced on the freezer side.
warm air will blow out from the condenser fan which is in the same area as the compressor.
There should be no warm air inside the freezer of fridge.
Jul 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Describe your FFU2124DW12 Problem The freezer works very good and gets very cold, But the outside walls and top gets EXTREMLY hot
Freezers have tubes that run inside the walls and top of the case, these carry the refrigerant thru the heat exchange process, this will cause the outsides and top of the freezer case to get warm/hot some times, this is normal, but I recommend you to make sure there is at least 1 1/2" of ventalation clearance around the entire freezer so that it can exchange heat efficiently.
If you don't think the amount of heat present at the outside of the freezer case is NORMAL, then I recommend contacting Frigidaire directly and discuss this with there customer service people.
1-(800)FRIGIDAIRE
GOOD LUCK !!
Aug 03, 2010 | Frigidaire Freezers
I keep my freezer in my garage, and It is warm out there, but I've noticed that the sides of my freezer is very warm to touch,on sides is this natural. it has been a very good freezer, and is almost 20 yrs...
Most units now use condenser coils hidden inside the walls of the unit verses exposed in the back. If your unit does not have exposed coils or a forced air cooled condenser then they are most likely in the walls which would make what you are describing completely normal. Just make sure you allow 3 to 4 inches of room around them to let the system cool itself.
Jul 08, 2010 | Kenmore Freezers
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
The sides of the freezer feels very warm. Is this ok?
Good day,
That is normal, and by design. The condenser tubing runs inside the outside walls on that machine.
Thank you for using FixYa
Dec 15, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Unit get hot on side
Freezers have their condenser coils in the outside, near the sides and all wrapped around. This part gets warm/hot during operation. The evaporator coils is around the inside wall, right next to the food. This coil gets cold when the freezer runs. It's a fairly efficient way to route these coils, and they don't need to have a fan this way.
So this is normal.
Oct 04, 2009 | Frigidaire Freezers
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer has been warmer than normal lately
check the door beeding which make seal between the body and door.Clean with mild cold water and check it is sealing properly while it is closed.check the compresor ,it should be light warm not hot.
Jun 03, 2009 | Refrigerators
GE 16.7 Upright Freezer
HI the heat on the outside of the cabinet is normal. the freezer is now working properly give it 24 hrs thanks.
Jul 17, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Freezer problem
if you don't hear it running for extended periods of time (more than 15 minutes) without stopping, and if it does not immediately re-start once it does stop, and if it is extremely hot climate outside (85 F and above), then yes, this is acceptable.
Jun 08, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kitchen Ranges Logo
14 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
