Question about RIM BlackBerry Pearl 8100
My blackberry 8120 cannot switch on at all. but it shows that it is charging by showing the red light when being connected to a charger
Your battery might have died. Another problem is some circuit or the power button isn't in place or broken. I suggest you open up you phone- but ground yourself first (get rid of static)- and check the circuits and the power button, if something isn't right, don't touch it. Take it to a phone dealer especially if you have a warranty. If not, pay for repairs. Much more economically smarter too than buying a new phone. Any other questions? computerfreak1995@hotmail.com
15 yr. old computer freak,
Alpha Chaos
Posted on Aug 27, 2010
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
My Blackberry refuses to Start Up
There is an issue with your firmware. You will need to do is:
1. Unplug BB from PC.
2. Launch the "Application Loader" like you were going to install something.
3. While the app loader is attempting to connect to the BB, plug the USB cable into the BB.
Apr 01, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
My usb port is damaged on my blackberry can not charge it how do I charge the battery? I cant charge it via the usb port which is needed for almost everything. is there another way to charge my blackberry...
The only thing you can do is use another BB to charge up the battery, and then swap batteries. Someone usually has a broken BB (screen dark, sound stopped working etc) which they will give you for free..
Jan 01, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry curve 8900, red light will come on for eight seconds when connected to AC power then a battery with a blue lightning bolt will show up on screen. Once AC is removed device goes blank. I've put...
The battery is drain.
DO NOT use the USB cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Use the official AC charger to charge the Blackberry.
Make sure the AC power is not switch off to the power pack at night.
The mini USB connector can be loosen over time.
Plug in the cable and check for connectivity.
Oct 19, 2009 | Cell Phones
BLACKBERRY BOLD HAS NO POWER,WILL NOT TURN ON. THE ONLY SIGN OF POWER IS THE RED INDICATOR LIGHT TOP RIGHT....ON SOLID. CARRRIED OUT REBOOT TAKING OUT SIM AND BATTERY. ANY ADVICE WOULD BE APRECIATED.
I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
Oct 15, 2009 | RIM BlackBerry Bold 9000 Smartphone
8300 wont boot up
Have you tried a different battery? Is the battery swollen, indicating it is damaged?
Have you tried booting up the phone with only a charger connected (remove the battery), this will tell you if it is the battery or the phone.
Jul 25, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My blackberry 8320 wont turn on no blinking nothing not even
Try a new battery or have your battery charged on another 8300 series phone, then install it in your phone. Typically, if the battery is below a certain voltage ("dead") the charging circuit does not become active, therefore not enough voltage to turn on your 8320. Also if it has been dropped or got water damage, these can also cause that problem.
Mar 06, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
RIM BlackBerry  Pearl  8100 Logo
43 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
