Question about LG Televison & Video
I have one LG 21" color tv ( MACH 4 model) and it is not getting start.It was working properly with some hissing sound but yesterday it didn't started, the LED at the front panel is glowing but TV is not getting on. I think there is some ESP power supply problem, can you please suggest which parts needs to be replaced and what is the approximate cost of these parts.
  • 70 Answers
Hissing sound comes from leak EHT transformer but front LED working means your power supply is ok so you need to check horizontal out out Transister and series resitor feeding to voltage from B+ to that transistor if it's gone pls replace the EHT transformer as well
in srilanka EHT is around $5 and transistor is $1
thanks
Posted on Aug 27, 2010
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
I have one LG 21" color flat tv (magic eye) and it is not getting start.It was working properly with some hissing sound but yesterday it didn't started, the LED at the front panel is glowing b
Hi Manher
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 20, 2014 | Televison & Video
Tv lg m197wd
It's dead. Off to repair center or to store to buy a new one ...
Apr 07, 2014 | Televison & Video
Sound lg tv
Check for any loose core [ferrite core] at the backlight inverter board, or main power supply switch mode transofrmer.
Jan 10, 2014 | Televison & Video
LG 29" COLOR TV HAVING MODEL NO. RF29CA40 plugged in and switched to standby mode it starts making a clicking sound. I can't get it to switch on it just sits clicking away in standby mode
my tv exactly same problem , from what ive read our tv 's are not worth the ammount it would cost to fix , around 250 dollars, im gutted! il let u know when i find out properly
Sep 19, 2013 | Televison & Video
Philips magnavox tv model 9p5511c101
if it was working ok before then ring up and complain and get him back as he did not do the installation properly.
Jun 09, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Our tv is Samsung DLP HL-P4663W 46 in. Rear Projection HDTV-Ready Television After having our TV on for about 45 minutes it starts to make this hissing sound which starts low and gets louder and louder,...
hello
This looks like a colorwheel symptom, does the sound is like a mechanical sound? high pitch sound? winding, whirling or screeching noise ? well if this is the color wheel, what i think it is, it seems that it is not working properly when this happens the DMD board recognizes that it is not spinning at the correct RPM and turns off the Tv for sercurity reasons, so if you want to replace this yourself what i recommend you to do is to open the back of the Tv and search for the colorwheel it can have missing parts or it could be shattered or it could not spin correcty, hope this info. can help you.
Jun 14, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
3-4" thick vertical line on 42" sanyo plasma tv
its most likly caused by either vert controler along bottom of set or ribbon to that part of the controler if you heard a hissing sound most likly is the controler itself
Jan 28, 2010 | LG 42PC3D 42 in. Plasma Television
Colored lines across TV
what this sounds like is that you may have a cable in the wrong part of the tv like maybe a vcr or audio cable check your inputs in the back of your tv that sounds like it what it might be i have a big screen tv and if i have a cable in the wrong part it will hiss and have lines on it too i hope this can help if not reply to me at Jonk3y @aol.com
Sep 23, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Televison & Video Logo
158 people viewed this question
Computer Repairing
Computer Repairing
