Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Dss25KSRCSS Appliance started making a "whining" noise -- appears to be coming from freezer section. The noise ocillates in pitch, high to low like a wave when the freezer unit is running.
  • hsantucci Feb 02, 2009
    how to get rid of the howling sound on the freezer side
    Director Badge:
    Uploaded 100 video answers.
  • GE Master
  • 488 Answers
this video will help you
Posted on Jun 27, 2015
  • 828 Answers
Sounds like your evaporator fan motor bearings are telling you it is time to replace the fan motor.
Posted on May 26, 2008
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
I have a GE model GSL25JFTA BS that was making a high pitch whining noise coming from where I believe was the freezer area. If I shut off the power it stops, but after a short period of time it returns. A...
Sounds like the evap motor and can be found at appliance parts pro part # AP3875639 $44.36/ the mother board if you would like to know is part #AP4436216 $134.95 but i would not waste the money.
Sep 28, 2010 | GE Refrigerators
Constant high pitched whining noise. Increases
you could be low on transmission fluid check that and make sure it registering properly on the dipstick.
Oct 20, 2009 | 2003 Toyota Sienna
Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
High pitched sound from fan
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hss25gfpdww The unit makes a horriable high pitch whining noise a
I am not posotive, but it sounds like you may have a piece of debris stuck in the fan underneath. You can check if you pull it out from the wall, make sure you unplug it as to not have the fan come on while you are toying. But thats what it sounds like. If that is not it, I am sure you could locate the noise with it pulled out from the wall, and go from there, Possibly your compressor, but sounds like the fan the way you're explaining it. Good luck
Feb 14, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whining noise from freezer
Fan motor is bad and needs to be replaced.
Nov 26, 2008 | Refrigerators
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ge side by side - high low humming noise from freezer section
Sounds like its the evap fan motor to me. Not very easy to axcess. I have had one GE make the same noises you are describing to me. Let me know if you are going to attempt it and need more assistance
Nov 19, 2007 | Hotpoint HSS25GFP Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
453 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
