Question about Canon PIXMA MP160 All-In-One Printer
I have the canon pixma 160 Inkjet printer.....when tryng to print, it gives me the error message 5010 ...i just refilled my cartridge...also i tried removing the usb wire and switched it off and then removed the mains power ..then re started it.... still doesn't work...HELP Thanks a lot
  • 472 Answers
This error is caused after pulling the printer to bits to fix a blockage. You can fix it by inserting the ribbon cables from the scanner into the circut board properly.
Good Luck!
Posted on Aug 27, 2010
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
My Canon Mp190 Pixma printer refuse to print after I put new cartridges in. What can I do?
do you see any error message on LCD screen?
Sometime, if you put refilled cartridge, you may see some error such as E5 (cartridge is not readable)
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 02, 2011 | Canon PIXMA MP150 All-In-One InkJet...
After refill my cartridge firstly it shows cartride is not properly installed.After that when we give print command it shows service error 5010. my printer is pixma mp 140.
Error 5010 Possible solution. I did this and it worked but I do not know if the solution is related to the printer's error code. 1. Unplug printer....wait 30 seconds then plug it in. Make sure the unlock symbol is on unlocked. you can find this when you lift up the heavy top cover to see the paten. 2. Reset. Turn off. Turn on. Reset 3. If this does not work. Look inside close to where the paper comes out (from the front.) There is a little door that can be flipped up or down. Flip this door up. Repeat steps 1 and 2.
Jan 19, 2011 | Canon PIXMA® MP460 All-In-One InkJet...
Error code 5010 is showing on my printing and i don't know how to fix it.
I pressed the reset button - as recommended for the cartridge to be detected and ..miracle: the cartridge problem vanished as well as the error 5010 message!!!!!!!! I printed a document with no problem...
Hope this has helped you... Thanks...
Jul 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP460 "np paper"
Canon PIXMA MP460 error code 5010
Sep 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Won't print
plz reinstall the drivers for the printer
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP950 Ink Refill Error
replace the cartridge with a Canon as the chip has gone on the cartridge.
this is the only way around it with the mp950.
This is to stop them being refilled
May 22, 2008 | Canon Pixma MP950 All-In-One InkJet...
Canon Pixma MP600
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Nov 04, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  MP160 All-In-One Printer Logo
55 people viewed this question
old marine
old marine
