Hard disk is detected in BIOS setup, but after boot it shows "DISK BOOT FAILURE, INSERT DISK" So what can i do now
  • Computers & ... Master
  • 27,725 Answers
It means insert your copy of windows operating system to finish the installation if you already have a operating system on your hard drive and if you dont wish to remove it when in bios scroll down Adavanced bios features and change settings on first boot device
Posted on Aug 27, 2010
Loveno S10-2 - No bootable device found
Make sure your hard drive has higher priority in the boot options in BIOS. If it still doesn't boot then you will need to replace your hard drive. If it shows no hard drive in BIOS then the drive is most certainly bad and needs to be replaced.
Dec 02, 2012 | Lenovo IdeaPad S10-1211U Netbook
HAVE REALTEK RTL8101E/8102E ETHERNET CONTROLLER PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING PXE ROM LOOP. HAVE TRIED ADVANCED BOOT . CAN I USE RECOVERY DISK INSTEAD OF VISTA DVD WHICH I DO NOT...
It is important to isolate the cause of the "PXE-E61 Media Test Failure, Check Cable" error and solve it. To do this, follow the steps below:
  1. A loose or improper hard disk cable connection can be the cause of the error. This typically happens if the hard disk has recently been installed or moved. Check all of the hard disk's cable connections before trying anything else to solve the error.
  2. Make sure that no other storage device is connected to the computer. If there is a storage device connected, remove it.
  3. When computer start up is being attempted, enter the BIOS to see if the hard disk has been set up correctly and detected in BIOS. To enter the BIOS, follow these steps:
a. The key that must be pressed to enter the BIOS varies depending on the computer model. The key is most likely the Del key or one of the F keys. Many computers refer to this as Entering Setup and Setup is just another term used for the BIOS.
b. Try setting one's BIOS to any safe default settings. That might fix the error.
  1. Verify that the boot options in CMOS are setup correctly. Follow these steps to do this:
a. Enter the CMOS by pressing one of the following keys: F1, F2, Del, Esc, or F10. Press one of these keys when trying to start up the computer. If these keys do not work, try holding one or more keys on the keyboard when the computer is booting. This may cause a Stuck Key Error, which should allow the user to enter the setup.
b. If the CMOS setup shows an option to boot from the LAN, disable this option.
c. Try to set the CMOS settings to any safe default settings, then save and exit. After changing any settings, reboot the computer.
  1. It is possible that physical failure caused the error if the hard disk cannot be detected. If this is the case, replace the hard disk and restore one's data if a good backup is available. If one does not have a good backup, contact a company that provides data recovery services. These companies perform hard disk recovery and securely retrieve one's valuable data.
Check that the drive is detected in BIOS:
  1. Press F2 during boot to enter BIOS Setup.
  2. Go to the Boot menu.
  3. Check the Boot Drive Order.
  4. Press F10 to exit BIOS Setup.
If Boot Drive Order shows No Boot Drive:
  • Check that the drive is properly installed in the computer.
  • Try installing a different known good drive.
If PXE Boot is enabled in BIOSTo check the BIOS option:
  2. Go to the Boot menu and check for Boot to Network.
  3. Press F10 to exit BIOS Setup.
If you do not plan to boot to a network, disable this option.
If you do want to boot to a network, check that the network cable connection is working properly.
Dec 29, 2017 | Toshiba Satellite Laptop
I have a w3622 and put in a new hard drive and tried to use the OS disk that came with the computer. what I get is PXE-E61: media test failure. check cable. Disk boot failure.insert system disk.
Sorry to hear about the trouble you are having. Try the following tips and lets see if we can get it up and running.
-Set the boot order in BIOS to boot from the disk drive first. In order to get to the BIOS, you will need to select BIOS option or Settings when the machine is booting up.
Most often, the above error is caused due to incorrect BIOS settings or a faulty hardware, such as hard disk. Sometimes, the error may also occur if the computer tries to boot from a device, on which it cannot find the required boot files. An improperly connected hard disk is also known to cause the same type of issue.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
Regards,
G33k
May 09, 2011 | E-Machines eMachines Desktop PC
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
Acer 5534 will not boot up....tried recovery disk....but nothing......error message PXE-E61-media test failure..........no bootable device
Hello:
Your Acer laptop is not detecting a bootable device, for sure your hard disk is:
1.- Malfunctioning and has lost its master boot record.
2.- It can be ruined and must be replaced.
In the first case, primary and recovery partition are bad, as you mention the recovery process failed (ctrl +F11). First, press F2 during POST, when "a enter Setup message" is prompted on the bottom of screen to check if the hard disk is listed on the Main BIOS properties. If detected, the hard disk can be recovered booting from DVD-ROM. In the BIOS setup utility, you need to select boot from de DVD-RW. Insert Windows 7 setup disk and it will check for possible boot errors, choose repair when prompted. Follow the instructions. The system will restart.
If the hard disk was not detected in BIOS properties, you should ask Acer for guarantee.
You may review this link for further information: http://www.acerlaptoprepairs.info/aspire-5534/
I hope this helps. Thanks
Jan 30, 2011 | Acer Computers & Internet
Aspire One N214 Model # ZG5 keeps showing me a Acer screen before informing me that I have a Media test failure and that it has no bootable device. I have no boot disk it asks for, Please help me!
The media failure means either the hard disk has failed and therefore cannot boot up the notebook.
Try reseating the hard drive first, so it makes proper electrical contact. If it still fails to boot up, then go to the BIOS setup and check to see if the BIOS detects the hard drive. The BIOS may have a hard disk diagnostic program, if so then run this program to check the hard disk. If the hard disk is faulty, then a new hard disk is needed and install Windows on this hard disk plus the Acer's device drivers and your programs to get a working computer again.
Sep 10, 2010 | Acer Aspire One PC Notebook
I have a latitude c610 and on start up a message saying media test failure check cable.can any one help.
Press F2 to go into the BIOS and reset it to factory defaults and reboot the laptop. If you still get the same message, go back into the BIOS and see if the hard drive is showing up in there, if it is then that means the OS has corrupt files and you would need to wipe out the drive and restore the laptop back to factory defaults.
If the BIOS doesn't show the hard drive in the BIOS then that means the hard drive is bad and would need to be replaced.
Jan 01, 2010 | Dell Latitude C610 Notebook
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
The COMPAQ splash screen displays, with F1-Setup and F10 system recovery option, but then displays 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'. This is my sisters computer, and she says there...
You may be able to purchase a system disk from Compaq, otherwise, try any generic XP disk. It won't have any Compaq drivers, but at least you can reformat the C: drive and get XP on it.
Nov 27, 2009 | Compaq Presario S6300NX PC Desktop
System is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Aug 14, 2007 | Intel Motherboard
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
