Question about GE Dryers
Dwxr47e dryer squeaks horribly. we changed the Axel unit,but it continues to squeak . it is North American model and European repairmen haven't been trained in it's repair. please help!
  • davidjota_ja Aug 29, 2010
    The sweak sounds like it is comming from the upper drum region
    It isn't the Bearing. I replaced the old bearing with a brand New GE bearing when I had the squeak. Please stop telling me it is the bearing. It is something else and it is loud!
  • 10,319 Answers
The squeak is caused by a dried up bearing in the belts idler pulley or the felt surrounding the drum itself
Posted on Aug 29, 2010
  • GE Master
  • 8,220 Answers
That squeal is cause by the rear bearing getting thindwxr47e dryer squeaks horribly. we - 2fcab8a.jpegMost of the time. You say you replaced this part? If this was left out you would hav a bad squeal. LOL I have repair photos here How it works:GE dryer
  • Dan Webster
    Dan Webster Aug 29, 2010
    Run it; raise the top up and look for the source of the sound.
  • 10,865 Answers
Hello David. Test to see if squeek is less noisy when dryer is empty -- load should make noise louder
Also note if it is continuous or happens every time the drum makes a revolution...
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
Posted on Aug 27, 2010
Constant loud squeaking
Squeaking is normally caused by a bad bearing or a slipping drum belt.
Feb 28, 2015 | Dryers
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
I'm trying t locate my IAT sensor on my ford escort 1994 and i cant find it
it is located on the inlet for the throttlebody on a section between the throttlebody and the air intake tube from the airbox. Do you have a North American model or a European model? The European model didn't require an IAT sensor. Just the North American model to meet EPA requirements. If it's a North Americal model, the sensor should be located in the air cleaner and have 2 small hoses attatched to it. have a good day !!
Jun 18, 2011 | Ford Escort Cars & Trucks
My dryer makes a horrible high pitch squeaking sound when it is in the dry cycle. It is about 11 years old. GE profile front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 05, 2011 | GE Dryers
When ever the dryer is running it make a horrible squeaking sound until the load is done. How do i stop it from squeaking?
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Aug 20, 2010 | Dryers
My dryer squeaks horrible while running. It has broken 2 belts in 3 weeks. What is wrong?
Jockey pulleys are faulty you will find squeak alters as drier heats....
Sep 29, 2009 | Dryers
Dryer won't heat up. I don't have a parts manual.
more than likely the theraml fuse on the back of dryer unplug unit and use a continuity tester to check for ohms. the t-fuse is on the exhaust tube also the squeaks usally comes from the drum rollers use a little silicon grease and lube the roller shaft
May 28, 2009 | Frigidaire FSE748GF Dryer
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Squeaks and sqeals during dry cycle
Lubricate the contact points, pulleys , change the felt seal .
Get a new dryer, abot time?
Vitally
May 14, 2009 | Dryers
Dryer squeaking & Clunking noise
Your particular unit has quite a few things that could be making a real loud noise.....The idler pulley, blower wheel, rear drum rollers, front drum glides. Bottomline is you have to get in there and take the unit apart..vacuuming while there and if the unit is making such a noise, it will be obvious where the problem is.....If I can help further, I am here.......
Eric Campion
Mar 04, 2009 | Dryers
Dryers Logo
95 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
