Question about Dell Audio Players & Recorders
My speakers will not play any music & everything is plugged in .
Think back, have u made any recent software or hardware changes to ur computer?
Posted on Aug 27, 2010
2006 infiniti m35 no sound from speakers
Yes an amp that is not working could cause this to happen. But I would check it out a little more because when you did the speaker test and all the speakers worked then that doesn't sound right. Find the amp and it could be just a loose connection that is giving you all these problems. Good Luck
Mar 12, 2014 | Car Audio & Video
Music hall mmf 2 not working with pre amp
The pre-amp has failed. Since you can hear the signal with the deck plugged into the amp that proves the cartridge and deck are working.
Apr 20, 2013 | Music Hall MMF-2.1 Turntable
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
Hiya i have recently moved my computer from the front room to a bedroom and plug everything in, i thought everything was fine until i tried to play some music so i checked all the connections/leads and...
Hi try looking over it again with the help of this https://www.download.p4c.philips.com/files/s/spa7300_79/spa7300_79_dfu_eng.pdf just make sure all connections are pushed in properly as those plugs have a tendency to not plug in all the way
May 04, 2017 | Philips SPA7300 2 Speakers
Sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Oct 18, 2009 | Philips (33-01-031) Headphones
Location of reset on unit
when you disconnect it from cables, it resets. But i believe that is not the problem. Check speaker cables. I think you have problem with internal power amps. They have thermal and current protection. look for short circuits on speakers or speaker cables.
May 30, 2009 | Sony CDX-GT500 CD Player
When i play music loud the sound cuts out
i would try getting a new amp, the speakers may be blown.
Dec 30, 2008 | Audio Players & Recorders
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
No sound
I've had my speakers for about a year now and all of a sudden they just stopped playing music/sound. I can still hear that 'fuzz' if I put either speaker up to my ear. Everything lights up properly but nothing is being played.
Sep 20, 2007 | Harman Kardon SoundSticks Computer...
15 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
