Question about Microwave Ovens
Baumatic btm 24 microwave 5yrs old. Internal 10A fuse blown. replaced and power restored (evident by digital read out working), but when actuallyswitched cooking power on the fuse blew again...
  • lukehodgson Aug 27, 2010
    Assume the magnetron is the metal box that generates the microwaves...have disconnected and all other funnctions seem to work. Presume a replacement magnetron is cost or supply prohibitive from your earlier comment?
  • Microwave Ovens Master
  • 11,800 Answers
The fuse blew because there's a short inside your oven. Since it blew when you tried to use it then it's in the power supply to the magnetron or the magnetron itself. Disconnect the magnetron from the power supply and try again:
   -  if now the fuse doesn't blow then the magnetron is dead - junk the oven.
   -  if it blows again then the power source is faulty: check the transformer, the rectifiers and the filtering capacitors for shorts.
Posted on Aug 27, 2010
  • Azrael SRL Aug 27, 2010
    Yes, this is it. It's price is indeed high - depending on where you get it it's between $25 for a second-hand piece from the internet (untested of course) to $250 for a new original replacement. But since this is a 5 year old device, finding a replacement will be difficult. You could try to find a generic replacement here
    http://a-1appliance.com/xref/magxref.htm...
    In my opinion - time for a new one
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Sep 12, 2014 | Panasonic Microwave Ovens
Switch on machine comes up as 5?
please follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 19, 2013 | Baumatic Microwave Ovens
Baumatic microwave BTM 25.1 SS not working
Bad Magnetron DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Microwave Ovens
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
There are condensation, water drips between the glass on the door of my over the counter microwave/convection oven. Is this a problem? How can I clean this? Microwave is only 6 months old.
HELLO.
Yes.Water can only drip between the glass on the door when the door do not seal properly due to dirt on the microwave door.follow these steps given below to clean the door.
Thanks.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven has died
Hi.
Check continuity of this 10A fuse to see if it's blown.
What is most likely to have happened, is that an internal short has happened inside the main transformer. These cannot be rectified, and often means scrapping the complete item due to cost of replacement.
However - if you can find another microwave with a different fault - just remove the good transformer.
Checking the transformer for a short at high voltage is not recommended.
You could try a spare 10A fuse as a start point (probably a leaded type) - but expect it to blow again. DON'T go higher or omit !
Sep 30, 2009 | Microwave Ovens
Emerson MW8106W Blew internal 20A fuse.
You almost certainly have a shorted high-voltage capacitor.
Here is a link you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Oct 19, 2008 | Emerson MW8106W Microwave Oven
Neff combi blown diode.
If the diode failed by opening, there may be no other damage. If the dioded failed by shorting, the alternating current may have damaged other components. Ohm it out. You can get diodes from digikey.com, mouser.com, or radio shack or any electronics or appliance supply. If the diode is charred and you can't get the part number, the oven rating can be used to select a replacement. Since the fuse was 10 amps, the diode should also handle at least 10 amps. If you can power the unit and read the voltage at the diode input this will give you the power (volts times amps). It's always worth trying as it's cheaper than replacing the unit.
Oct 14, 2007 | Neff H7871N2GB Convection / Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
