Question about Hitachi 42V710 42" Rear Projection HDTV
Hitachi Television Yellowing on the screen
I have a square section in the middle of my TV that is yellowing. What is the cause?
  • Apryl Duthie May 13, 2008
    Our Hitachi rear projection tv has had a yellow area in the center of the screen that I noticed about 3 months ago. It has since gotten larger, almost covering the whole screen. You can see true color at the edges of the tv but the rest has a deep yellow tone. I thought maybe something was going on with the bulb (discoloring on the glass, too hot, who knows) so I took it out, but it's the same color as when I installed it just over a year ago. I see there are quite a few of these (same problem) listed on the net, not just for Hitachi. Any info would be greatly appreciated. Imagine, a $300 tv from the 70's still runs but a $2000 tv from the 21st century s hooped at 3 years...that's progress : P
  • Anonymous May 19, 2008
    We have a Hitachi 42V710 Rear projection HDTV. It started having a similar problem with the Yellow spot in the center of the screen. The bulb has been replaced, but the problem seems to have gotten worse, covering a good 60-70% of the screen. From what I'm seeing with others and the cost associated with fixing the problem, it may be more cost effective to get a replacement TV. We have had the TV for only 30 months, and have changed the lamp twice. Of course the warrantee has expired.
Suggest you call Hitachi and complain. There is an issue with all projection LCD tvs (not just Hitachi) was that the light engine assembly did not have enough vents for cooling. This translates in a green or yellow blob that starts small and grows larger because the LCD screen frame starts to deform with the heat. Guess they did not test with young kids in the house and the tv on more than it is off :-). In March I managed to get Hitachi to pay for the part and I paid for the labor to get this fixed (out of warranty). The new light engine supposedly is better at cooling though I do see a faint 1/4 inch band of green at the bottom of the screen. Blackburn Electronics in Anderson IN has fixed many of these in the Indianapolis area.
Posted on Oct 07, 2008
MY HITACHI 50V720 HAS A YELLOWISH COLOR
Hello, I'm sorry to tell you that that set has a bad optical assembly. The blue part has gone bad and cause's either a yellowing of the screen or blue spotting or both. You can purchase a new lcd tv cheaper than you can repair that one. Do not replace the lamp, it's not what's wrong with it, and you'll just waist your money. thanks, Terry
Oct 08, 2012 | Hitachi 50V720 Television
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Yellowing on Hitachi 65T500 screen
Go to main menu, turn color all the way off to see if you have perfect black and white. If you still have yellow, it's in the focus block or convergence circuit, If it's perfect black and white then it's going to be in yc chroma luminence circuit.
Nov 22, 2011 | Hitachi 65T500 65" Rear Projection...
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Yellowing picture
Its a light enine again, excessive heat from lamp causes this, either getting dust in fans or ducts around engine,
Jun 30, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi 61" TV-objects on screen have yellow shadowing
The convergence circuit of the TV is causing this. You will need to have your convergence output ICs replaced. Expect to spend $350-450 to have this issue fixed.
michtech
Feb 12, 2009 | Hitachi 60UX58B 60" Rear Projection...
Yellow discoloration on screen
the screen is yellow green color all the we have had it worked on once already does anyoblemne have any comments on how to solve this problems?
Jan 27, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Yellow and blue on screen
I am slightly confused about the model of the television, because a 46F500 is a rear projection set that doesn't have a lamp. It has 3 picture tubes and I have a few of them in my shop right now that have the problem you reported. What we do to this set when it develops a convergence issue is to check each resistor around the convergence chips for discoloration, and replace any of them that have changed in value, along with the STK392-150 ic's. If you don't have an ohm meter and solder/desolder equiptment, you can usually get a shop to do this repair for 150.00 to 350.00. Parts will be 50.00 and labor , the rest, depending on the quality of repair shop that you use. Good luck, Russmann.
Nov 16, 2008 | Hitachi 46F500 46" Rear Projection...
Hitatchi ultravision 53" rear projection lcd tv
You have a problem with the optical engine- The only repair would be to change the engine for about $500-$1,000 plus labor. This is a major repair (sometimes caused by dust particles getting on the LCD panels inside the engine, but disassembling the engine to try and clean it is not a reasonable option)
Aug 21, 2007 | Hitachi 60V500 60" Rear Projection...
Hitachi 42V710 42" Rear Projection HDTV Logo
316 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
