Question about Microsoft Windows XP Professional SP2
Blue screen error - Microsoft Windows XP Professional SP2
  • Azrael SRL Aug 27, 2010
    So what is the BSOD says? What's the error?
  • 1,218 Answers
The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Posted on Feb 22, 2011
Dell inspiron 570. 1 beep on start up. black screen. 1 light on the front
if you need support for your Dell inspiron 570, Blue Screen of *****, Fix Blue Screen Errors, Blue Screen Error in Computer, Blue Screen Error in Laptop, Dell Technical support Number, Dell computer support, Dell laptop support Number 1-800-204-4427 (toll-free) and more... http://www.delltechnicalsupportphonenumbers.com/blue-screen-of-*****
Jun 24, 2017 | Dell Computers & Internet
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors
The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors
However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
Update Windows - missing updates, including service packs can be a source of stop errors.
Check your system - run a virus scan and spyware scan after updating your definition files.
Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
How do i fix my computer with a blue screen that keeps shutting it off?
Post your OS please!
Oct 01, 2010 | Computers & Internet
I cannot load windows it gives me the blue screen than dumps the memory
There are many possible causes for blue screen errors. Faulty memory, device drivers, viruses. Try to analyze the blue screen error by looking at the error code and the event log, so you can find the right solution.
Here are some ideas: http://www.pcauthorities.com/pc-errors/how-to-repair-blue-screen-errors
Jun 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
Why my laptop always blue screen after play games
try to reinstall the videocard drivers or your laptop is not recommend for gaming or replace memory card
Aug 16, 2009 | ASUS LGA775 SOCKET FOR INTEL CORE2...
Blue screen is coming
There are 3 step to repair blue screen error If you got blue screen error then there is a 94% chance that your computer has registry problems. To repair blue screen error you need to follow the steps below:
  • Step 1 - Download a Perfect Optimizer,install this error repair tool.
    * Step 2 - Click the Repair All Button.It will scan you pc for Free.
    * Step 3 - Then click the Repair All Button again and your done! It is very easy to repair blue screen error.
    Here are the url of Perfect Optimizer: http://www.errorremovers.com/tidporp-blue_screen_error-zz0005
Jun 04, 2009 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional SP2 Logo
99 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
