Question about Manfrotto MagFiber 190MF4 Tripod
Breakdown Manfrotto 3265 ball head from 190xb tripod
I am having trouble breaking down the tripod for shipping. I have removed the 3 set screws from the 3265 ball head unit, but it won't come off the tripod. Can you hlep?
  • AmLo May 07, 2008
    Ha ha, I fixed it!
    There is a hole at the bottom of the ball head unit. By inserting a screwdriver in the hole I used it as a lever to rotate the ball head unit off the tripod. Luckily in Italy it's lefty loosey, righty tighty like it is here in the US.
    AmLo
  • 24 Answers
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
Posted on Jan 30, 2009
How do I replace a leg release lever of a manfrotto 190XB? One of the three leg release levers is missing. I ordered a spare part (R190,304), but I don't know how to put it in place.
Hi Stefan
Possibly some bad news for you..., the Part #R190,304 you ordered is not made for the #190XB tripod..., it is for a model several years older (though it MAY fit)..., (see link for correct parts diagram)!!!!
http://www.manfrottospares.com/download/pdfs/190XB_20061025.pdf
To easiest way to replace one of the top leg castings is to first remove the centre column and then support the tripod in such a way that the (3) legs are not touching the ground (i.e.: all the weight is supported by the casting through which the centre column would normally mount. You will then need to undo the (3) screw (allen key style) that pierce this casting...., (the reason for wanting to support the tripod via the bottom of this casting is that all the small parts SHOULD stay in place when the top casting is separated from the lower casting. Once this has been done..., carefully remove the leg with the damaged top casting...., replace it (making sure the new one is facing the right direction) & then reverse the procedure.
Hope this helps
Peter
Aug 12, 2014 | Manfrotto (190XB,128RC) Tripod
How do I get a product manual for the 190xb?
You can look on line at manuals.com or from the manufacture's website
Aug 02, 2014 | Manfrotto 190xb 3 Section Aluminum Tripod...
How do I tighten my Manfrotto 3265 ? After 15 years of use, it is slipping and not supporting my camera.
Check out the videos at http://bogentripodparts.com/repairs.htm the second on the leftside deals with this problem. They also do reapirs.
Oct 19, 2013 | Bogen Communication Bogen Manfrotto 3265...
Tripod leg stuck
loosen the allen head screw for that legs snap lock
Mar 13, 2013 | Manfrotto (190XB,128RC) Tripod
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
I need a lower leg clamp for my 190xb manfrotto tripod.
You can order the lower leg clamp as a part from http://bogentripodparts.com/parts/190XDB.htm
Follow the link and check for your part number.
Hope this helps,
Andrew
Oct 05, 2009 | Manfrotto 190XB Tripod
Need a user guide for a Manfrotto Bogen 3265 grip action ball hea
Hi, This should get you to what your looking for, Go to this web site : http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
Feb 25, 2009 | Nikon TRIPOD, BOGEN PRO WITH PISTOL GRIP
Manfrotto MagFiber 190MF4 Tripod Logo
1,045 people viewed this question
Top Manfrotto Photography Experts
JP Services
JP Services
Tom Chichester
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
