Question about Canon Elura 100 Mini DV Digital Camcorder
I have a Canon elura 100 just has blue screen and says Canon. It powers up but everything else is useless other then seeing the blue screen that says cannon on it.
    Genius:
  • 1,812 Answers
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
5 Suggested Answers
SOURCE: Canon Elura 60 - Zoom is on maximum and won't restore
I too have the same issue. Honestly, the only solution that I have found for it is to knock on the top of the camera where the button is located. The PHOTO button on my camera stops working at times also. The knocking normally fixes that too.
Posted on Jun 13, 2007
SOURCE: Camera won't record
Yes, solution #1 works! Thanks!!!
It took me a while to figure this one out but I finally did and mine is back to working perfectly. The problem: The Play option worked fine but the camera did not. When turned to camera mode the blue canon screen would come up and then freeze. The only way to turn it off was to remove the battery.
The fix: I was brave enough to take the entire outer shell off the camera. On the main board, underneath the screen/battery side, all the different parts are connected together. There is a single connector from the lens that had come out of its port. The ribbon connector must have somehow been shaken out of the port at some point. With needle nose pliers I carefully fit the ribbon connector back into the port. I carefully reattached the outer shell and everything was back working!
I will warn you that this task takes some time due to many many screws. It's a lot better than sending it off for hundreds of dollars though.
Posted on Nov 14, 2008
MNfisherman
  • 11896 Answers
SOURCE: card error
try to reformat the card either from camera or pc. If reformating doesn't work, then try a different card. Some camera's are touchy when it comes to the memory cards
Posted on Nov 12, 2009
arian07gapa
  • 62 Answers
SOURCE: Canon Elura 100 tape will not eject. Pops out but
stockk up inside..
bring it to repair shop!!
Posted on Apr 07, 2010
Card error
Nov 12, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 60 won't power up
The same thing happened to mine soon after I got it. Turned out the plug I was using to plug it into the wall to charge had gone bad. The replacement was over $100 so I went with a (cheaper) wall battery charger that you conect the battery to.
Nov 09, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Won't play tapes, just stays on the blue screen
ok. what you need to do it hit the side where the tape goes in...start out slow and then gradually hit harder and harder...not too hard though...because it sounds like a hardware jam...you need to unjam it by shaking it up a bit.
Jun 28, 2008 | Canon Elura 100 Mini DV Digital Camcorder
I have a Canon Elura 100 that "thinks" it is playing back a video and the tape is winding in the machine, but all I see in the viewfinder is a blue screen and there is no sound.
Try connecting it to a tv with the audio video cord and see if you get anything then. If not then there is probably an internal problem. which i know that from one repair Camera company would cost 199 to get anything internal fixed so you will want to try to get a local repair person to look at it and maybe its jsut a simple fix.
Jun 26, 2008 | Canon Cameras
Camera won't record
Hi!
First of all, English is not my natural language, so please forgive me. My canon elura 100, bought in the US 1 year ago, had the same problem. After a big fall (from a second floor), the camera landed in wet sand and after that the camera won't record again (it plays the recorded files just ok). Just today i had the time to check the camera, so i disassemble the camera and found a poorly connected cable, that goes from from the lens body to the motherboard of the camera. After reconnecting this cable the camera start recording again.
regards
May 18, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Downloading my camcorder
See to it that you have an OS which is XP version or Vista Version. then Plug your camcorder, if it detects low power transfer the connection at the back of your PC, then double click you my computer icon see if another drive come out, if it has then thats it, double click the new drive then locate all your files then copy and paste it unto your PC.  if still didn't work out I'm sure it has a CD suite then install it. Thats it..
Mar 23, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 100 Power Dead
Just an update.
I sent it back to the factory - and they fixed the power unit.
However, they told me that now my Memory card and memory card operations will not work.
They did not charge me for it - they took it under warranty.
Everything else seems to be working.
Oct 23, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 60 - Zoom is on maximum and won't restore. I own Canon Elura 60 since last two years and now i'm facing problems with zoom. Zoom button does go to and fro but actual zoom doesn't take...
Hi There, did you find any resolution for this problem? If you could share any info about the problem, it will be really great. Even I have the same issue with my Elura 70. Thanks.. Pradeep
Nov 08, 2006 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 100 Mini DV Digital Camcorder Logo
81 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
