My Toshiba laptop hangs when I plugin the power AC, but it works fine when running on battery. I am able to charge the battery when laptop is in sleep or shutdown mode. I have the latest BIOS. What could be the problem?
I had same problem, i try ti use free Rightmark CPU Clock/ Power Utility (RMClock) 2.3.5 to set cpu power management and it work for me, my laptop running fine until now, its had been three month since i had the problem. Thank to NGO "Science Center RightMark".
Posted on Nov 03, 2010
    President:
  • 2,291 Answers
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Posted on Aug 27, 2010
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Hi. I have a Toshiba laptop a205 s5812. The problem is when I start it with AC adaptor connected it wont start. If I start it without connecting the adaptor it works fine, but once on if I connect the...
Although this may only be a temporary solution, try connecting the adapter but taking the battery out. Now try turning on the laptop. It should work. Unfortunately, this means that you will need to always connect the laptop to the wall when you want to use it.
Mar 21, 2011 | Toshiba Satellite A205-S4777 Notebook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Battery problem not working or the power button not working,,Why?
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 09, 2011 | Toshiba Computers & Internet
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
Power button
hello
Follow the instructions.
  1. Take out the battery and the Ac power. Keep the power button pressed till all residue power is radiated.
  2. now connect the Ac power without the battery and try to start the system. Hope you have fixed the supply with proper soldering.
  3. if the system gets start then there is no problem with your system hardware is OK.
  4. now try battery. charge it fully and this will tell you if your battery is good.
  5. if it works with power supply but not with battery then there are two possibilities.
  • battery gone
  • charging module in the mother boad malfunctioning.
Thank you
Aug 16, 2009 | Computers & Internet
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
Battery does not charge
PLEASE CHEK THE BATTERY LED ON WHEN U CONNECT THE AC POWER TO THE SYSTEM.
Jan 11, 2008 | Toshiba Satellite M35X-S149 Notebook
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
