Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F35 .error on screen. What is going on with my machine
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
  • Agus Yustiara
    Agus Yustiara Aug 28, 2010
    you have to replace part no.W10156252-water level switch...
Start washer it fills with water and then go to suds right away while it is empty, then try to restart and it shows F35 on screen
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Sep 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is an F35 code?
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
Feb 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front load is making error of F35 and sometimes would say SUDs. I don't understand why it saying that. It won't do any washing at all.
The F35 error meams there is a problem with the Analog Pressure Sensor. This sensor is near the back right of the machine (viewed from the front) when the top is removed. It has a hose going to it and an electrical connection.
Replace the sensor
Thank You
Sep 06, 2010 | Whirlpool Washing Machines
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine stopped with code of F35
F34, F35 and F36 are fusing errors.
To unlock:
- Turn off machine
- Turn it on while pressing keys 2 and 5 simultaneously
- On the menu that shows up, press 1st option "Software SW"
- Using the up and down keys, navigate to switch 3-1
- Press OFF
- Cycle machine power
Don't mess with anything else or you'll risk more trouble than you're having right now.
If the error comes up again, you have something wrong with your fusing unit. Check it.
Mar 06, 2010 | Washing Machines
Washing clothes all day have an F35 flashing
F35
If this failure is displayed, there is any malfunction of the steamer
Possible Causes/Procedure
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Check these problems.
Plesae leave a solved rating before you leave the site
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal De
