My screen on my tv keeps going black and eventually stays thate way
    Problem Solver:
  • 6 Answers
Replace T-CON board
Posted on Aug 27, 2010
How do i fix a vizio 42" tv with a black screen, no sound
THE MAIN BOARD AV BOARD HAS WENT OUT JUT HAPPENED TO ME TODAY
Feb 28, 2013 | Vizio Razor M421nv 42" 1080p Hd Led Lcd...
Hi i have a 42" LG lcd tv .When i switch it on
the inverter for the backlight likely has a bad capacitor or more. The fluctuating high voltage is causing the jumping and eventual blackness until sufficient charge is on the caps, at which point it stabilizes...it eventually will stay black unless the caps are replaced.
Mar 05, 2011 | LG 42LC2D 42 in. LCD HDTV
Black streaks in the screen there is a black streak on the right side of the screen
the tv will eventually completely go out because lcd tv's are very fragile and if it is in the inner side there is no fixing it. keep kids away. lol
Nov 28, 2009 | Sova DSV32P112 32 in. LCD Television
RCA light comes on and then goes off. Tv doesn't turn on
replace CP150 and CP114 you can get them at the following link they also have the ITC222 service manual which is listed under Thomson as Thomson makes your TV for RCA. The Capacitors are listed under the RCA parts and they do send instructions with pictures of where the capacitors are located as well as how to remove the board.
http://servicemanuals.vstore.ca/
May 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen goes black tv stays on. Turn off and on and TV's fine.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Mar 20, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
I have a Sony TV KDF-E60a20 that keeps going black screened during use. It usually stays black for about 2-3 minutes and then comes back on. It is becoming more frequent.
this is usualy caused by exessive dust on circuit boards ,if the screen goes black and the sound stays on this may be your problem,beware tvs hold charge even when unpluged so would advise taking to shop hope this helps andy
Jun 22, 2008 | Televison & Video
Black Box?
my tv was working fine. somebody hit the menu button on the tv or the remote and i get the black box appearing in the middle of the screen. and also the pip is staying on my tv it keeps showing "a snowy picture of pip sjpwomg channels 2 through 18 i cannot figure out how to get this off of my screen.
Feb 08, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Televison & Video Logo
Top Televison & Video Experts
