I am first time user of LG Intellowasher 6.5 kg top loading washing machine. Please let me know how to use it, like loading water, clothes
  • 15 Answers
SOURCE: LG WFT851 - Flakes of dirt problem
try putting some milton or baby bleach into the machine with the hottest possible wash with no clothes with the highest water level
Posted on Jul 19, 2007
I was given a new model LG washing machine recently, it works as it should however the original owner was a builder and whatever he was washing off his clothes has caked onto the sides of the outer drum.
I have pulled the top off the washer and can see that the outer drum is literally covered with a fulll layer of this thick, black muddy greasy clay like substance. I need to pull the inner drum out in order to be able to get the outer drum but haven't managed to figure it out as of yet.
I've tried dissolving portions of the gunk with detergent, acetone, cleaning vinegar, methylated spirits, paint thinner, auto degreaser and mineral turpentine, of all these agents turps is the only one that seems to have an effect however it's ability to dissolve the stuff is minimal.
Posted on Oct 14, 2007
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
IFIXALL
  • 868 Answers
SOURCE: Kenmore Top Load Washer Series 70
NO,your transmission is probably ok!! Inside your top end of agitator are these 4 plastic parts called "dogs" they need to be replaced.To be 100% sure ,do this first,Fill upthe machine on small load and while its washing look to see if the bottom end of agitator is moving back and forth ,if it is replace the dogs.In some machines you have to change the upper part of agitator.If the agitator is not turning at the bottom than,remove the top of agitator cover so you can get a extended half inch socket in to it and pull the agitator up and check the transmission splines.If they are smooth and cannot grab the agitator than your trans, is bad.
Posted on May 20, 2008
MNTECH
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
WATER IS NOT DRAINING IN MY LG TOP LOADING WASHING MACHINE
The first thing I'd check is the water pump if the timer's working ok...
Mar 06, 2014 | Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Oily substance
most common is lint build up. a good hot wash with a good bleach...check your manual for manufacturer's recomendation. There's various products available..bleach is the most in-expensive and works well. make sure its set on high water level...pause machine for 10-20mins...let me know how you get on
Jan 03, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
157 people viewed this question
Top Washing Machines Experts
