Question about Samsung CLX-3170FN All-In-One Laser Printer
How do I use my printer as a duplex for making copies on both sides? Thanks Roxanne
    Sergeant:
  • 223 Answers
This is set when you select print for the print job, then choose "printer properties", and select Duplex (two sided printing) in the printer menu. Im not sure if this printer supports multiplexing, but have a look in the printer properties for that setting. choose it, then press ok and then finally print. I know this printer does multiple pages on one sheet but that is different that back and front printing. ... on a second look at the manual, I dont see this feature being supported by your printer, so in that case, choose to print odd pages first, then put them back in the drawer upside down and print even pages. (be sure to then tick off the reverse order button as well) try it on a small print job of 5 pages to get the hang of it first. cheers
Posted on Aug 27, 2010
  • 526 Answers
The printer does not support duplex coping. If you want to do manual duplex copying, you can make a copy of the first page.
Then reinsert the paper upside down in the manual tray or paper tray, fil the page on the document feeder and make the back copy.
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, or make a note if your still having trouble.
    Thanks! Gurvy
  • abbyk36 Sep 02, 2010
    Hi, I just got this printer and want to print documents using both sides of the paper. I noticed your response (gurvy) to the original question. Do i have to individually print every odd page, or is there a way to ask the printer to print only the odd/even pages.
    Thanks
    Abigail
When I make a Duplex copying,it is copied at the wrong position only on the front side.
check that you are using duplex and left binding. also does this happen with other files??? does it happen with different program pdf , word etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 20, 2015 | Sharp Mx-2310u Color Copy/print/scan
Bizhub 211 double sided printing inactive
It was the same problem. To enable drop down menu open "Device Option" tab where you will see list:
Duplex Non Instaled
Tray2 Not Installed
Tray3 Not Installed
Just double click on "Duplex Not Installed" and it will changes on "Installed" and Double sides drop down menu become active.
Jan 20, 2012 | Konica Minolta bizhub Office Equipment &...
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
Trying to make dual sided copies and it says Duplex Unit not set please set. How do I set it?
firs you have to check the duplex unit connector disconnect and reconnect the same -thanks
Jan 05, 2011 | Gestetner DSm745 Black and White Copier
Cannnot copy a double sided document to cardstock
This is normal. The cardstock is fed from the manual feed or bypass tray and when selected the duplex option goes away. Many manufacturers do this....meaning they do not allow duplexing from the bypass tray. For the same reason they do limit automatic duplexing to standard or near standard papers. Cardstock is specifically excluded from duplexing obviously due to it's thick nature and when duplexing the paper has to be turned over and go thru paper paths that are not suitable for thick paper. If you must make a 2 sided copy using cardstock you will have to run the sheet thru the machine 2 times, also known as manual duplex.
Hope this helps.
Apr 12, 2010 | Copystar - CS-3035 Printer
How to make automatic duble sided copy on IR-2000
these machines have a duplex unit all machines this size does, now a duplex unit is where the paper double sides in the machine, like doing a double sided copy.
i know off some people think that a duplex unit is the DADF (document feeder).
May 31, 2009 | Canon imageRUNNER 5570 Copier
Duplex copying
sorry but you haven`t duplex on your machine. you need to buy dublex unit or you can print on one side end insert the paper again and print on the other side.
May 19, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
Light copies when duplexing copies
You can try to replace the transfer and sepperation corona wires and the post corona wires. Also, make sure the corona hieghts are set to the door spec's. If that is not good enough try to replace the transfer unit.. Imay need more info.. for any more ideas..
Jun 06, 2008 | Canon NP 6050 Copier
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Good luck and please rate me, thanks.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
Samsung CLX-3170FN All-In-One Laser Printer Logo
395 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
