Question about Casio fx-300ES Calculator
My calculator gives me the answers in fraction form, not decimals, and I would like decimals instead. Help me!!
  • Casio Master
  • 7,993 Answers
Press [SHIFT}[MODE] to enter (SETUP). Select [2:LineIO].
Posted on Aug 27, 2010
Decimal mode casio
Your problem is not with the scientific display, rather it is with decimal representation (approximate) or fraction/radical (exact). representation.
If your results are in fraction/radical form press the [S<>D] key to switch from one to the other.
The calculator is by default in the MATHIO t output mode: results are in fraction/radical form.
If you don't like to work with this mode just change the IO mode to LineIO. To do so, press [SHIFT][Mode](Setup) and selct 2:LineIO
Oct 07, 2013 | Casio fx-300ES Calculator
How do you convert an answer in the form of a decimal into a fraction?
The TI-83 can only convert a decimal to a fraction if the denominator has no more than three digits.
Try . 5 MATH FRAC
Does that give you 1/2?
Sep 17, 2012 | Texas Instruments TI-83 Plus Calculator
How do I have my casio 115 es give answers as decimals instead of fractions?
To convert a single value to/from fractions, press the S<>D key.
To get all answers in decimal form, press SHIFT [MODE] 2 to select LineIO mode.
Aug 16, 2010 | Casio FX-115ES Scientific Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
Answers in decimals
The calculator has two Input/Output modes, MthIO and LineIO. In MthIO the results are displayed as fractions or as radicals or a mixture of fractions and radicals. What it means, is that in MthIO the calculator does exact calculations. Radicals in denominators are gotten rid of by rationalization, fractions are reduced to the same denominators before addition or subtraction. Fractions are reduced to simplest form.
In LineIO all results are displayed as decimal numbers.
If a result is exact (fractions and radicals) it can be changed to decimal form by pressing the S To D key, the one above the DEL key.
MthIO is the default IO mode. To set it, press SHIFT MODE and select 1:MthIO. To set LineIO as the IO mode, press SHIFT MODE and select 2:LineIO
Jan 20, 2010 | Casio FX-115ES Scientific Calculator
TI-89 decimal to fraction
Here is what you do:
1) Press the Mode button.
2) Scroll down the list that appears until you find "Exact/Approx".
3) Change the setting for "Exact/Approx" to Exact.
4) Press enter to save the settings change.
You have three possible settings for "Exact/Approx":
1) Auto - The calculator will try to determine the best format.
2) Exact - The calculator will always give the answer in fraction form.
3) Approximate - The calculator will always give the answer in decimal form.
Nov 15, 2009 | Texas Instruments TI-89 Calculator
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
Reset calcuator
try this, press shift mode, then line 10. It will make it permanent. the answer will always be in decimals. if you are using a casio with ES models.
Jun 14, 2009 | Office Equipment & Supplies
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Casio fx-300ES Calculator Logo
64 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
