My pc is showing "Setup Entry Key Detected" and its not starting when restarted and just showing the bios settings screen. Please help me out for this problem.
  • 22 Answers
Setup entry key could be "DEL / F2 / Enter" depending on BIOS manufacturer. So, the key might have pressed/stuck/short circuited in keyboard. You can try plugging off the keyboard for the start. Some BIOS need keyboard to boot. Anyway, if you're not seeing the BIOS Config after plugging out keyboard, the keyboard key is the problem here. Try swapping with another one or hit those keys for few times. Good luck.
Posted on Aug 27, 2010
How to enter bios asus on my asus v550c
On systems with Windows 8 pre-installed, you can access the UEFI (BIOS) setup screens from the Windows 8 boot menu:
  1. Press the Windows key + C, or swipe in from the right edge of the screen to open your Charms.
  2. Click Settings.
  3. Click Change PC Settings.
  4. In PC Settings, select General.
  5. Under Advanced startup, click Restart now. The system will restart and show the Windows 8 boot menu.
  6. In the boot menu, select Troubleshoot.
  7. In the Troubleshoot menu, select Advanced options.
  8. In the Advanced options menu, select UEFI Firmware Settings.
  9. Click Restart to restart the system and enter UEFI (BIOS).
How to access BIOS on an ASUS laptop
Dec 06, 2013 | Computers & Internet
PXE-E61 media failure check cable
PXE-E61 Error message showing due to Media cable failure.
You have to fix this media cable failure one must return to the BIOS screen at start up. Depending on the model of the laptop, press f1, f2, or delete to enter the BIOS screen (the computer will tell you what keys to press). At the bottom of the BIOS screen, there will be a menu. One of the options should be "setup defaults." By pressing the corresponding key, it will return all of your settings back to how they where originally.
Hopefully it will help you
Jun 26, 2013 | ASUS X401a 14.1-Inch Laptop Black Intel...
I can't install Window Xp sp 2 in My Compaq CQ45 .If i stall Xp sp 2 ,it can't found HDD..
Restart your PC and go into BIOS Setup. For some computers BIOS setup keys are F2 and for others its Del key. If you are not sure which key takes your computer to BIOS setup. Start pressing F2 and Del keys alternatively immediately after you restart your machine. Make sure that your HDD (Hard disk Drive) is detected. If its not detected and appearing in the BIOS setup than most probably you have to open your hardware which is not recommended if you are a beginner. There can be a number of reasons like loose wiring and bad jumper settings on the hard disk id the disk is IDE.
May 05, 2011 | Computers & Internet
My acer aspire9410 disply is blank,i entered many time bios setup key F2 but it not showing bios setup page, pls help me to get in to bios page. before i tried lot one it was showing but it showing like...
-changeing bios-first restart computer then press[ f2] then get on key board use arrow key on key board go down you will see your boot log is on f2,change that on a f12, now push f10 to exsept settings now when asked restart computer then f12 then run windows under D:drive.
Feb 26, 2011 | Acer Aspire 9410 Notebook
How to install change first boot divice on ibm thinkcentre computer
You must enter the "BIOS" at start up (sometimes called SetUp). Press F2 or F8 or F11 or other function key that will be required by your computer. Should tell you at boot.
Enter the BIOS settings, find the boot sequence and edit it. remember to save your changes.
BE VERY CAREFUL WHAT YOU SELECT!
Thanks for your visit today.
Feb 01, 2011 | IBM ThinkCentre A50 PC Desktop
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
Pc "bios"problem
this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
Dec 21, 2009 | Intel Computers & Internet
Everytime we boot up our computer it says press f1 to do something and f2 to enter setup mode?
generally an indication that something is wrong in the system setup. Press F2 and enter setup, check the time and date settings and the system event log (If BIOS has one) for incorrect settings, also check and see if the BIOS shows a hard drive installed.
If time and are wrong, set them to correct and save settings. If system keeps losing time and date after power is removed, then the backup battery may need to be replaced.
If HDD is not detected, then reseat it. If still not detected replace it.
Dec 10, 2009 | Dell Inspiron 600m 1.6GHz Pentium M...
WHEN LAPTOP IS SWITC\HED ON..IT STAYS ON THE TRAVELMAYE LOGO WITH A THIN RED LINE TO THE RIGHT AND A THIN WHITE LINE TO THE LEFT OF SC\REEN.////////IF LAPTOP IS POWERD UP WHILST HOLDING DOWN F2 BUTTON..A...
ok..enter to the bios setup and then find "load bios setup default" and then save and restart the system.
If won't help then, verify if the hard drive is detected..if don't know how to detect hard drive, go to bios set up and find hard disk if detected. if not hard disk found then ..consult your vendor for immediate support.
melnavz
Oct 22, 2008 | Acer Computers & Internet
Original setup was interrupted
press F8 key (just after BIOS screen) at the next cold reboot and you will see a DOS screen with 3 or more options. Read each of them and I think you will see one option is to resume setup. This option places the system at a safe entry point to continue the setup. Another option may read "cancel setup and restore previous system"...this one may be used if you cannot get the "resume setup" option after repeated tries.
Aug 03, 2007 | Compaq Evo N610C Notebook
Computers & Internet Logo
2,253 people viewed this question
David Payne
David Payne
