Question about Refrigerators
Hi I have no water being dispensed from water outlet when you try to fill glass. Have tried that there is water flow to bottom of door when you disconnect pipework joiner there. Everything else is good, have no filter in fridge at the moment as thought it was blocked but was not the problem. Any ideas to try would be appreciated. Thanks Nigel
  • nrsmeaton Aug 27, 2010
    Yes the plug is installed in place of filter as detailed in owners manual.
    It seems that there is a blockage between the connector behind the kick panel and the outlet where the water would normally dispense. i had this joiner disconnected and it will let the water flow correctly when you push touch pad with glass, but when i connect pipe joiner together again it will not come out at top.
    Thanks Ginko
    The water is flowing again, must have iced up the water line, all goog now, thanks heaps
    Nigel
  • Refrigerators Master
  • 19,396 Answers
Hi Nigel.
A first test to do is a complete defrost, or a controlled defrost of dispenser unit, used an hairdryer set on cold air (so to not damage the fridge). Better performing a complete defrost if possible. This will exclude possibility of frozen ice blockage on the dispenser side (you have already tested the rest of the lines).
If that does not help, then problem is either the dispenser actuator or the dispenser inlet valve, in that case the dispenser must be taken apart to test the part.
Both parts are tested using a multimeter on Ohms and reading if the switch is opening and closing, and if the valve as continuity when circuit is open. Before disassemblying remember that this can affect your warranty status.
To find parts and diagrams for your appliance, enter the model number in the links listed below:
Where do I find parts and diagrams?
Posted on Aug 27, 2010
  • 1,998 Answers
You have to have the filter installed in your fridge for the water dispensor to work also have u checked the switch on the door under the front panel its connected to the arm that you push when you try to get water write back with your finds ty again rickead1
Just installed a new Bosch fridge, ice dispenser dispenses ice but water does not dispense?
Make sure it has water on the container and no obstruction on the water dispenser. Try several times. Since it was new unit, sometimes water has not yet completely fill the dispenser tubing hence it will not dispense water.
Look for some carton, foam or plastic obstruction around the dispenser, it may cause hindrance of not flowing water from dispenser into the glass.
Thanks for asking.
Jul 03, 2011 | Bosch Refrigerators
Water in door is not coming out very much intermiient
There is a mesh screen filter in the water supply line where it connects to the water inlet valve on the back of the unit. You can disconnect the line coming out of the valve and try the dispenser to see if it comes out normal. You can disconnect it at the bottom of the freezer door to see if it comes out normal there. If it does the water could be freezing in the door. Leave the door open till it thaws out. Cover the freezer with a blanket to prevent loosing too much cold air.
If you have a water filter it could need changing.
Nov 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water from dispenser very slow
You could have a piched H2O line somewhere near where the door connects at the bottom front corner or a bad water valve could be the issue. There should be a water container in the rear of the inside of the fresh food side that stores water. Make sure its not leaking or has any obstructions to it or the lines to and from it.
Sep 21, 2009 | GE Profile Stainless Bottom-Freezer...
Water collects in bottom of freezer, then it runs out in the floor after ice has filled the bottom of the freezer. I have a frig with water and ice in the door. The ice maker is working fine, but the water...
there is a chance that the bottle that holds your water in the fridge compartment.could be broken or a line maybe disconnected this would cause water to leak in the fridge compartment.this bottle is designed to hold the water and get it cold before dispensing to your glass
Sep 16, 2009 | Refrigerators
How to increase the water flow from water dispencer on a FLSC238DSO when getting water it takes for ever to fill a glass
If your fridge has a water filter, you should change it every 3 months. An old filter can cause slow flow problems.
But it will never come out as fast as the kitchen sink. Depending on the location of your fridge, you have 10 to 25 feet of 1/4" pipe between your water glass and the high-flow plumbing, and water just won't move very fast through that.
My water dispenser flows very slowly. The unit is
Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
Thanks for using fixya
proton
Aug 14, 2009 | Refrigerators
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
Water leaking out of bottom of fridge....
brand new??? if so this is quite normal, youll need to "purge" the holding tank andthe water lines of any air in the lines, generally pulling 1-2 gallons of waterthrough system is addequate
Jan 15, 2009 | Whirlpool Refrigerators
Wont dispense water
Did you check the pump at the bottom of the fridge ,and also the solenoid. valve to release the water ,does it click when you depress glass against sensor in dispersal area
Dec 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is extremely S L O W
check no ice build up in bottle but the most likely cause is poor water pressure on the inlet. no cure except to improve water pressure. if there is a valve in the input water line, check it is fully open
Apr 25, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
