Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
The swing mixer handle has become very stiff. how do i get it off to clean it/
    New Friend:
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Posted on Jan 29, 2013
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Turn the water supply off to the faucet before you start and open the faucet handle.
Remove the setscrew under the faucet handle.
Pull the handle off.
Remove the bonnet nut.
Lift off the bonnet packing.
Disconnect the sprayer hose from under the sink.
Pull the entire hose out of the faucet.
Swivel and lift the whole spout assembly off the faucet body.
Replace the faucet body O-rings.
lubricate the O-rings and the inside of the spout with waterproof grease.
Assemble the faucet in revers order.
Posted on Aug 27, 2010
Group handle is leaking water when extracting
Most of the time, it is the guarnizione sottocoppa, the group rubber gasket that has become stiff or worn. Sometimes, it is the filter basket that has been flattened or nicked from not using a proper battifondi, or knock box, and as such is damaged and will not form a good seal.
Last on the list is a worn handle, specifically the "ears" that you guide into the group to make the seal. When connected to the group, the handle should point to 5 or 4 O'clock. If it points to 3 or maxes out, this may be remedied by ordering paper spacers (shims) that are to be installed first, then the new gasket. Usually 2 shims do the trick.
Aug 20, 2014 | Nuova Simonelli Musica Black Espresso...
Sometimes the pucks do not fall into removable container. How do I fix this?
Make sure the swinging arm at the top of the brew unit moves easily. Check nothing on the brew unit is damaged. Servicing the brew unit might help.
Brew Unit
The transmission can wear out prematurely due to the brew unit becoming stiff. The piston in the brew unit should move smoothly and fairly easily. Keep the brew unit in good service by occasionally removing the piston to clean and re-grease the two big red o-rings using a food-safe grease. To pop the piston out the top, gently remove the plastic u-clip from the base of the shaft underneath, paying attention to which way up it goes for reassembly.
Jan 22, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
How to stop my grips slipping?
Put the grips in hot soap'water let them soak .take them out let cool off clean and rinse them off with luke warm water after cleaning them also inside the grip hole, clean the handle bar with alcohol. Put them back on and twist them till they become a bit stiff than let it dry. It will grip the handlebar.
May 29, 2011 | Freestyle Mongoose Bmx & Owners Manual -...
My mixer started chugging at the higher speeds, blowing out fine dust out the top of mixer
Your mixer has a build up in the motor of all the goodies you've prepared. If you feel qualified, unplug your mixer and use a DRY, stiff bristle brush to gently dislodge the particles. A dry toothpick can also be use to dislodge. Once you feel you've gotten most of the powdery gunk loose, turn the mixer upside down and tap it gently to allow all the gunk to fall out. Then plug it in, turn it on high and let the fan do it's work to blow all the stuff out. It this doesn't work, you'll need to take it to an applliance repair store to have it cleaned professionally.
Oct 28, 2010 | Vacuums
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
May 03, 2010 | Dishwashers
I replaced the cartridge on my Moen single handle kitchen faucet (the old cartridge had become quite stiff). Everything went back together fine. Now however there is alot of slack in the handle when the...
You need to get the handle back on properly there is a groove on the handle that connects to the top lock nut older models had a chrome nut newer ones had a black plastic one
Nov 17, 2009 | Plumbing
The faucet handle has become stiff to turn off and on, and to switch between cold and hot. I have loosened the screw with an Allen key, but cannot remove handle.
The handle has build up in it but should come off eventually. Sounds like a dry o-ring seal. You can purchase a kit for your model without having to replace the whole unit.
Jul 03, 2009 | Blanco Classic Single Handle Faucet with...
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
On and off handle becoming very stiff
change the insert or washer thank you for useing fixya please rate me
Feb 19, 2009 | Blanco 157-090-CR Rados Kitchen Faucet...
Mixer taps
you didnt mention which side hot or cold?
it sounds like its scaled up & the o ring has dried out so it could be a case of replacing o ring & regreasing. ifits when you turn either hot or cold & its stiff then a replacement cartridge will required
Kindly
Richie
Aug 29, 2008 | Plumbing
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
1,986 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
