Question about Roper RT21AKXKQ Top Freezer Refrigerator
The bottom portion of the frig no longer works, at all, but the freezer does. replaced the thermostat but the frig still is not getting any colder. The thermostat is set at "normal". What else can I try?
  • Roper Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Roper brand, not that old--no ice maker--freezer ok, but frosts up--BUT a loud knock comes from the back, not constant and not all the time--if I turn the thermo, to get the bottom colder, it frosts up...
Is the frost on the evaporator cover in the freezer? If so, then you have a defrost problem ( bad defrost heater, defrost thermostat, or defrost timer/ Adaptive defrost control).Does the knock in back happen when the frig shuts off? If so its probably your compressor. Check you warranty.
Sep 25, 2011 | Refrigerators
Put in garage now unit will not keep cold or freeze.
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
Temp is erratic too warm, too cold ....
Sounds like the defrost timer is not working correctly or the start capacitor is malfunctioning,Both are cheap and easy fixes.
May 09, 2009 | Refrigerators
Frig warm, Freezer Cold
I have experienced this with other refrigerator freezers. The most likely cause is that the warming element in your automatic defrost system is no longer working. Ice is building up on the cooling coils and this prevents the refrigerator from getting cold. I have always called an appliance repairman to fix (~$150). If you're handy you can try yourself, but you still have to buy the part at retail. Good Luck
May 03, 2009 | Refrigerators
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
Too cold in frig
Check for a faulty thermostat it is responsable of shutting down the compressor when it reaches your desire temp.
Jan 19, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Frig not working but freezer is
check and make sure you dont have frost on the back wall of your freezer on bottom and make sure fan is working
Dec 29, 2008 | Maytag MCD2257HES Side by Side...
Refrigerator has uneven temperature from top to bottom
if frost is building up in your freezer you have a defrost problem,is the freezer fan working?can you remove the freezer panel so you can check the defrost heat and defrost sensor?and last check the defrost timer in the frig. or on the front or back of frig.,let me know what you find-mike
Nov 15, 2008 | Refrigerators
Frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
47 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
