Hi, my GE Spacesaver fills water very slowly. thanks
  • 1,998 Answers
Check the water valve check your hoses unscrew hoses to assure there is no debris in you line reattach and test again if you still have low water pressure and your assured that it is not coming from your faucets then you would do a power test on the water valve to assure that you are getting power to both sides of the valve please write back with your finds. please remember to rank how this opinion has helped in your appliance situation and have a great day
rickead1
Posted on Aug 27, 2010
Replacement of cold water valve on ge model wpgt9360eoww washer
Is this a new development or has it always done it slowly? Before jumping to parts changing, make sure it isn't something simple like a kinked or obstructed hose or even something like someone nearly closed the supply valve!
Dec 02, 2014 | GE Washing Machines
The water will not stop flowing into the ice tray after it has filled.
Chances are that the dual water control valve on the ice maker side is defective and not shutting off all the way allowing water to slowly leak by and mess up the freezer with frozen water everywhere. The replacement part is=> WR57X10051 Water Inlet Valve
If the water is simply an extended over fill after ice maker refills that will be caused by the ice maker itself. WR30X10093 Ice Maker Assembly
If you have questions please ask, Thanks Sea Breeze
Jul 11, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE PFS22MISBBB. On the back exterior of the appliance the waterline to the icemaker pushed itself out of its connector and leaked water on the floor. I shut the water off and inserted it back into...
Sounds like ice blockage or other foreign material is built up inside of of fill tube. Try removing hose and visually inspect fill tube. Sometimes a slow drip will freeze tube shut. Replace fill valve if it continues to drip and freeze.
Sep 18, 2017 | GE PFS22MIS
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
The water filling the ice maker freezes in the filling tube.
You can thaw the frozen water with a hair dryer but to stop this from happening the water control valve may be the reason for this to happen. When the ice maker calls for water to refill it is timed. If the water control valve located on the rear of your refrigerator is not closing all the way for the ice maker side it causes the water to freeze in the tube because it slowly flow to the ice make just enough to seal the fill tube.
Thanks and let me know what you find, Sea Breeze
Oct 12, 2009 | GE Refrigerators
Microwave no longer heats; makes no sound or buzzing noise
hi..it sounds like a magnetron problem.It might have
got into damage.
check this out..
thank u..
kindly rate my response..
Jun 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
Water Dispenser
water fill valve or if equipted need to cnage water filter
May 06, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Washing Machines Logo
Top Washing Machines Experts
