Question about Toshiba 50H72 50" Rear Projection Television
Violent shaking picture initially but slowly tapers off but still shakes
My Toshiba 50H72 rear projection TV picture violently shakes initially and distorted, but acts like poor reception, ant tapers off with minor shakes and distortion. Is there a part I could order and replace it myself to correct the problem?
  • iamfun09 Oct 12, 2008
    My Toshiba is very blurry and shaky when i turn it on. After it is on for a few minutes, it all goes away. But this problem occurs every time I turn it on. What seems to be the problem and how can I Fix it?
  • benny5000286 Apr 14, 2009
    waivy picture when turned on it was lasting just a few minutes now it takes 30 to 40 minutes to go away and it dose not totally go away. If
    I use my hi-def cable box the picture is clear only on HD shows.
I have a 50h82 with the same problem as above,please help,billy
Posted on Oct 07, 2008
  • 121 Answers
Do you have a service manual for your tv? If not I would suggest you get one because there could be several things causing this I will post a website whre not only can you get a manual for your tv but they also supply free online tech support to help you troubleshoot and fix your problem
Posted on May 06, 2008
Rear end shakes violently at low speeds
Very good possibility that you have a tire with a belt that slipped.
Sep 04, 2017 | 1996 Ford Ranger SuperCab
Violent shake on highway
Unbalanced wheels shake a vehicle like that. It's hard to understand your earlier statement. It sounded like after you weren't moving anymore that it still shook. I am figuring that isn't what you meant.
Nov 27, 2013 | 2003 Cadillac CTS
Ford f250 diesel 4x4 truck problem
check the drive shaft joints for worn/siezing
Feb 20, 2018 | 2004 Ford F250
It sounds like you have a bad CV axle
Jan 12, 2010 | 2004 Saturn VUE
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Shake in steering wheel
I believe you need your disk brake rotors turned to be true again or have them replaced. Whe you use your brakes a lot and kit puddles of cold water then it will warp the rotors which will cause the violent shaking. You may not feel it in the brake pedal even if it is warped rotors. If you don't think you have warped rotors then you should be very careful driving it because it will probably be in the steering sector arm or the idler arm on the steering shaft.
Jan 04, 2009 | 2006 Nissan Xterra
2000 Pontiac Sunfire that Shakes Violently around 45-50 MPH
Check the ball joints and cv axles this could cause the car to shake violently and most tire stores will check them for you for free.
Dec 20, 2008 | 2000 Pontiac Sunfire
Frigidaire front-load stackable washer has violent shaking cycle
The Shipping bolts need to be removed from the back of the unit?? they go thru a plastic sleeve once the bolts are out you can twist the plastic peice to remove them completely I think there are 3 of them
Jan 24, 2008 | Frigidaire GLTF1670A Front Load Washer
Toshiba 50H72 50" Rear Projection Television Logo
682 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
