Question about Nintendo Wii Console
Our wee disc is caught in the machine and we are unable to eject it any ideas how?
    Novelist:
  • 142 Answers
If both the eject button on the Wii and the eject option from the Wii menu are not functioning than the gears of the the disc drive are broken. Your only option from this point is to send the Wii into Nintendo for service. Sorry for the bad news.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Posted on Aug 27, 2010
Testimonial: "thks"
2004 Ford F150 rear entertainment system will not eject dvd, will play the dvd and will run when eject button pushed but will not eject the dvd any ideas on how to get the unit to eject the dvd?
The unit is connected by small set of gears that push tray /disc out. As tray comes out it either pushes disc out of slot or pops open door (depending on which style of face you have). If you have kids I would not be surprised if something is caught in between disc and face or jamming edge of door. (know this from own experience). The face of player can usually be carefully popped off by gently prying at corners. If you get face off you may be able to see if something is stuck in unit that does not belong, or see if a piece is broken loose near face. If unit has door that opens you can try using a slim but stiff piece of plastic and keep tension on door with plastic while hitting eject button. On some units there is a small hole on face that is manual release that ejects disc - even if no power. Usually takes a long straight push in hole (straightened paper clip or dental pick) and it manually pushes gear set to go out. So many of these units are different but most do have a manual release. Check owners manual to see if it shows a picture of face and possible release hole. Have had kids fight over changing a disc and pushed in on it while it was ejecting so it stripped gears, and had kid hang on ceiling mount unit that tore screen totally off. I feel your pain....
Jan 21, 2015 | 2004 Ford F150
Minidisc will not eject
Try unplugging it and plugging it in the next day. It sounds bizare, but it works for me.
Jun 04, 2014 | Sony MDS-JE440 Mini Disc Player
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Wii game was stuck halfway in machine kids couldn't get it to go in so they tried to force it till I caught them and stopped it. Pulled it out and when you try to put a disc in there is a grinding...
The best option to fix this problem is to take it to a service center unfortunately, but here are a few question you need to know the answers for to be able to get the best service:
1. Was the Wii on when they tried to force the disc in? If not then the noise could be that the motor mechanism has been jammed and the worm gear for the motor has been stripped. You will need the disc ejector mechanism replaced.
2. Was there another disc in the machine at the time? If there was, it is possible that the first disc has become lodged in the machine and could have been broken into pieces, so when the disc is entered or ejected, sometimes it will go in and sometimes not. When there is vibration the disc pieces or even the whole disc could move in and out of the way of the tray. You would also need to have this removed by a service technician.
Wii consoles are notoriously fiddly to deal with when it comes to repairs, needing special screwdrivers and a keenly trained eye to be able to spot a problem in an extremely confined space.
I'm sorry I could not be of more help but I hope this helps you even a little.
Jul 15, 2011 | Televison & Video
Game disc not ejecting
The problem may be that you have something caught between the disk drive and the rest of the system,if you can unlodge the piece of **** clogging up your system it might eject properly.Hope it helped
Oct 15, 2009 | Nintendo Wii Console
Disc gets caught and don't eject
make sure there is no dirt inside the slot... get a peice of thin pipe and blow into the slot to clean all the dirt
May 29, 2009 | Sony PS3 40GB Best Sellers Bundle Console
PS3 will not read any discs
The laser lens might be damaged. Is your warranty still available?
Jan 29, 2009 | Sony Playstation 3 (PS3) Console
Panasonic dvd recorder model dmr-e55eb/ebl. played dvd,no problem - ejected dvd - green/blue colouring appeared on TV which disappeared when dvd recorder switched off. since then unable to play dvds. ...
This is a problem with either the logic or the power supply. Without seeing the machine and taking measurements inside, I can't state for sure the exact problem. These are decent machines. I would suggest that you bring it to an authorized Panasonic service center for a repair estimate. Post the results here and we'll suggest the next steps.
Dan
Apr 23, 2008 | Televison & Video
DVD caught inside machine
When a DVD won't eject, the most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the DVD. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) try to find the motor and belt which operates the DVD loading & eject mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the DVD is why you may not have this problem during a load sequence.
Let me know what you find and we'll go from there.
Good luck,
- Jim
Feb 15, 2008 | Philips DVDR985 DVD Recorder
Nintendo Wii Console Logo
57 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
