The pump needs to be unblocked how do i do it? its a front loader
  • Steve Dallas Jan 31, 2012
    I juyst found this out the hard way with the "F21", or "slow to drain" message. You'll need a T20 Torx to remove the front lower panel, then unplug the washer, and get ready for about 1l of water to come out of the filter (backwash from the drain hose). I found coins and gooh in the trap that caused this message; make sure you use the "Clean Washer" feature afterwards to make sure you clean out the washer.
    Thank you for your help!
  • 1,998 Answers
You can check the drain filter by removing the lower front panel and the front top panel/door assembly.It may be accessible by just removing the lower panel. Once the panel is removed, you will notice a drain pump at the lower center right section of the unit with a hose running to the housing. On the front of the pump, there will be a filter twist cap. Twist and remove that cap and pull out the filter to remove any obstructions and debris that may exist. Once you have achieved a good cleansing, replace the filter cap and assemble the panel. Try to initiate a cycle. If the cleansing of the filter does not correct the spin out, this will confirm that the issues are serious and it will isolate the motor control board as the lone culprit.
Here is a picture of the filter cap and pump.
Posted on Aug 27, 2010
Loud wheezing noise on spin cycle
you need to unblock the pipe work from the tub to the pump ,,then the pump,, and the pipe from the pump to the drain
Jan 12, 2014 | Panasonic Washing Machines
Kenmore 417-48102701 front end loader washer. Won't go into spin cycle? Any thoughts of what to look for?
could be a number of problems,but try this FIRST push and hold any two buttons in for about 20 seconds make sure the machine is on,if this fails then you could have a blocked pump ie a sock is the usual suspect some mackines have a filter at the lower front check below the door if there is one then open and unscrew anty clock wise,if not then the pump will need removed and unblocked.adrianxxx
Jul 24, 2012 | Kenmore 44072 Front Load Washer
Washer won't drain. Pretty sure it's clogged but not sure how to check for this.
Hi, You don't mention whether this is a top loader or front loader. On the top loader you need to get to the drain pump. Front of washer may come off or the lid comes off and then the front. Some of them had clips under the console. Once you are at the pump, take a shop vac and empty the water. Both hoses inlet and outlet will have to be removed and cleaned. BEFORE YOU DO ANYTHING ON THIS, UNPLUG THE MACHINE!!! If its a front loader the kickplate has to come off or the whole front, and same procedure as above. Hope this helps.
Jan 18, 2011 | Washing Machines
Gray front loader washing machine
Check the drain pump filter for a foreign object and check your hoses for clogging or obstructions.
If there is nothing wrong with either of those, you will need to replace the drain pump.
Jul 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not spin or pump water out
Is it a front loader or top?How old? What model? need more info If front loader sound like you need to remove hose from pump and cheak for obstruction in pump good luck:)
May 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water stays in Gasket on Whirlpool GHW9400 Front Loader
The tiny holes at the bottom of the door seal are blockedcarefull push a small screwdriver through yhem to clear them out
Jan 09, 2018 | Whirlpool GHW9400 Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Wont pump water out after the washer fills
Ref. to manual to locate filter of machine, clean out. Caution unplug from mains. If that does not work you may have a block in one of the pipes coming down from under the tub (front loader?). You hv to unblock by disconnecting pipes. Next to look into is your pump, last.
Jun 09, 2008 | GE Washing Machines
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
