Question about Kenmore 22422 Top Load Washer
Washing machine My washing machine will not run. I started the wash yesterday.It is filled with water. To my suprise when i tried to re run the wash it started beeping at me and would not begin the wash cycle again. Its very new and it appears to have a grinding sound when i hit start.
  • maddiesmom May 08, 2008
    Please help. I started my washer and it started to agitate. when i dropped one more item in and closed the lid, the washer wouldn't start up again. It's a small load of laundry.
  • 975 Answers
THAT GRINDING SOUND is coming from the main motor , first you have to check a CAPACITOR located near the motor , disconnect it and try START AGAIN , IF it still giving you the grinding sound check if its coming from the motor , if so youre gonna need to replace it , cause the motor come from the factory SEALED ,making it imposible for repair,hope this helps AJ
Posted on May 06, 2008
My washing machine does not fill with water. It was fine yesterday.
You have given very little info about your machine. But with the possibility being a few . I can say . Its probably water inlet valves . Try hot wash . If the hot water flows then its probably your cold water inlet valve.
Apr 24, 2016 | Hoover Washing Machines
Wa75t65gw1
After 2 minutes does the machine throw up an error code. Starts beeping and shows a weird pattern of lights?
If so that error code can help us diagnose what your problem is.
If it does give you an error code take a photo and post it back on here so I can see what it is.
Jul 04, 2017 | Fisher and Paykel Washing Machines
Washing machine is going crazy. Help!
Check the pump/filter located at bottom front of machine. Usually gets blocked with small coins etc
Jul 21, 2012 | Washing Machines
New washing machine model wtw4800xq will not begin fill cycle -delivered yesterday and filled - not today?
Make sure it is level and that the drain hose is hooked up properly and not clogged. Check all electrical and water connections to make sure they are tight and turned on. Other than that You will need to call the people whom you purchased this and have them look at it becasue if you start trying to repair anything by taking it apart the warranty will be void. One other thing you can check is the pump filter under the tub. something may have gotten inside and plugged it up. If there is any water left in the machine it will not start filling.
Jul 03, 2011 | Whirlpool Washing Machines
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 30, 2011 | Washing Machines
MY WASHING MACHINE WONT START WASHING
Could be motor brushes or the motor....
Feb 09, 2010 | Washing Machines
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
Whirlpool LSQ9500LQ0 stops runs only for about 2 minutes
Try this first..Same thing happened to me yesterday..
I pulled the washer away from the water source..unscrewed the water lines from the water intake (not the washer)..there is a screen in the both hot and cold ...my screens were filled with debris..after cleaning the screens the washer works just fine..try this easy fix before you start looking into things like the motor or a switch somewhere...
Dec 19, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
