Any empty seat there ? - Computers & Internet
  • 342 Answers
This can be fixed by placing a empty board,by adding this your empty seat will be safe from dust etc.
Posted on Aug 27, 2010
How do i fix a jammed rear seat belt
You must remove the rear seat bottom and remove the bolt for the seat belt retractor, this will allow you to in jam the seat belt.
Dec 13, 2015 | Vauxhall Astra Cars & Trucks
Why does my older ef 1000 leak gas out of the carburetor overflow when not running until tank is empty?
needle and seat have dirt /hair in the seat
seat rubber on needle has failed
always turn the fuel tap off when not being used
Oct 31, 2015 | Electrical Supplies
Spitting petrol out side of carb
Your float is stuck or your float needle and seat are not seating well, allowing the fuel height to rise too high which then comes out the side. This is assuming that your float is adjusted properly in the first place. Pull the carb and pull the bowl and check for dirt in the bowel, check the needle and needle seat. check float height. You can also open the bowel drain, before you take anything apart, drain the carb. Turn the fuel on and see if you can flush it out after the bowel has emptied. You can also spray carb cleaner in the fuel inlet on the carb with the drain open and the carb empty. Not really a fix but might get you by for a while.
Mar 07, 2014 | Motorcycles
My 1997 Chevy C1500 Extended Cab passenger airbag doesn't show that its on only off?
The lt is seat activated by weight. If the light is off it is activated. When the seat is empty, no passenger or other stuff in the seat, the lt will show off and this normal.
Nov 04, 2013 | 1997 Chevrolet C1500
It runs fine for a few minutes then gas runs out of the crank case tube into the carb flooding it out. have cleaned it and put it back 3 times ,same problem. why
The float and needle are stuck open somehow. Check the float by shaking it to check for fuel in it. If not empty-replace it. If empty, does the float move freely? If so, then the needle is not seating properly, get a new needle and seat. The seat should be rubber, ie in a Tecumseh engine I know that it is vitron rubber. You can use a wood screw to extract the seat and the flat of a drill bit to install a new one.
I hope this is helpful for you, let me know.
Aug 22, 2011 | Yard Man Yardman Riding Lawn Mower 38in...
How to remove the seat
To remove the main seat, unlock and remove the pillion seat. Empty out the compartment below and you should find an allen headed bolt right at the bottom. Remove the bolt and thats the job done.
Jan 26, 2011 | 2006 Honda CBR 125 R
Power seat wont move Front to back, But the back of the seat will move
check if you have any upstickels under your seat. like coins, cigarett...empty beer can etc. :) maby give it a litle push when pushing the butten. good luck
Aug 29, 2009 | 2005 Kia Sorento
Clunking sound under driver seat
you have an empty coke can under seat and when carpet got wet it stopped rolling around
Jun 27, 2009 | 2002 GMC Yukon XL
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
